[Mapserver-users] Projection help
Kieran J. Ames kames at keyspanenergy.com
Fri Feb 28 13:23:14 EST 2003
This is a multi-part message in MIME format.
--------------E2C47CA71FC520DC10FE68BA
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
OH.... I'm so close!
Thanks to several listers, I've gotten ALMOST where I need to be. If someone
could help me with the lsat few feet of alignment, I'll be set.
To summarize, I've gotten (almost) all of my data sourced from ArcView
Streetmaps, converted to shapefiles. I added the following lines to the
beginning of my shapefile:
PROJECTION
 "proj=latlong"
 "ellps=clrk66"
#datum=NAD83 # NEITHER OF THESE COMMENTED LINES CHANGE
#  "ellps=GRS80" # ANYTHING FROM THE ellps=clrk66 DEFINITION
 "lon_0=0"
 "x_0=0"
 "y_0=0"
END
I have no other projection information included with regard to the DD data.
I then included Wetlands polygons from the Fish and Wildlife Service. Within
that layer, I included the following projection definitions:
  PROJECTION
    "proj=utm"
    "ellps=GRS80"
#    datum=NAD83
    "zone=18"
    "north"
    "no_defs"
END
These definitions I got from the associated .prj files.
Everything renders (Mapserver doesn't die), but the wetlands layer is shifted
about (best guess) 100' east-southeast. (See the attached image. The water is
overlapping Shore Road.)
I've tried changing datums, ellps names, etc,. between the two projection
definitions with no luck. Can anyone tell me why I can't get these layers to
line-up?
Additionally, I need some help in regular expressions in CLASSITEM. I want to
render all polygons EXCEPT for one type (Attribute = U). If I wanted to show
these, I'd say EXPRESSION /^U/. How would I say NOT the letter U?
Thanks for everyone's help thus far.
Kieran
Eric Bridger wrote:
> Kieran,
> I know little about projections, but recently got a UTM layer to display
> on my non-projected map. So here's what I found:
> 1) make sure mapserver was compiled with PROJ4 support: /cgi-bin/mapserv
> -v will tell you.
> 2) Create an overall map projection in the map file, near the top:
> PROJECTION
>  "proj=latlong"
> END
> 3) Create a utm projection for the UTM layer:
> LAYER
>   PROJECTION
>     "proj=utm"
>     "ellps=GRS80"
>     "zone=19"
>     "north"
>     "no_defs"
>   END
> 4) The other layers need no PROJECTION, will default to latlong
> 5) shpinfo.pl -file="your_utm_shapefile" will report the EXTENT in
> meters of the UTM layer. I started with a map file just to get the UTM
> shapes alone to display.
> 6) Caveates:  Maine and Mass are in UTM zone 19. Virginia is in zone 18:
> see:
> http://www.colorado.edu/geography/gcraft/notes/coordsys/gif/utmzones.gif
> My UTM data was NAD83 not NAD27.  Not sure how much difference this
> makes.
> HTH
> Eric Bridger
> On Wed, 2003-02-26 at 12:44, Kieran J. Ames wrote:
> > List,
> > I've never had to project data (until now) and would like to ask for
> > some help in trying this out.
> > All my data are either internally created or derived from ArcView
> > StreetMaps.
> > The only information I include in my map file are the UNITS DD statement
> > at the top and the scalebar's UNITS MILES statements. I have no other
> > projection information included.
> > I'd like to include the Fish and Wildlife Service's wetlands polygons,
> > but they are projected in UTM, NAD 27, meters.
> > Could someone tell me how I could include these layers to match up to my
> > decimal degree data? I'd want to include wetlands (coastal waters) from
> > Maine to Virginia.
> > Sample working map file layer definitions follow.
> > Thanks,
> > Kieran
> > LAYER
> >   NAME "Background"
> >   TYPE Polygon
> >   STATUS DEFAULT
> >   DATA 'National/Backgrnd'
> >       CLASS
> >         COLOR 162 202 240 # OCEAN BLUE
> >      END  # CLASS
> > END  # LAYER
> > LAYER
> >   NAME "North-America"
> >   TYPE Polygon
> >   MINSCALE 18000000
> >   STATUS DEFAULT
> >   DATA 'National/North-America'
> >       CLASS
> >         Name 'North-America'
> >         COLOR 109 185 14
> >         OUTLINECOLOR 0 0 0
> >      END  # CLASS
> > END  # LAYER
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: image/gif;
 name="GENERIC_MAP1046455337294.gif"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
 filename="GENERIC_MAP1046455337294.gif"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--------------E2C47CA71FC520DC10FE68BA--
