[Mapserver-users] no map, single black line (SOLVED)
richard hornsby rhornsby at io.osuedc.org
Thu Jan 23 16:22:00 EST 2003
It was a combination of things - bad ownership of the cgi and unexpected
path translations.  The black line was actually the 1 pixel black border
around the non-existent image, which I suspected.  duh.
Information Center, n.:
        A room staffed by professional computer people whose job it is to
        tell you why you cannot have the information you require.
rj hornsby . systems engineer . www.osuedc.org
human and community resource development
p 614 688 8761 . f 614 688 8762
On Thu, 23 Jan 2003, richard hornsby wrote:
rh :
rh :Sorry to bother everyone with this, but I'm stuck.  I've got the demo app
rh :running just fine, which seems to indicate that I've installed the cgi
rh :correctly, ie:
rh :
rh :  http://io.osuedc.org/mapserv/itasca/demo_init.html
rh :
rh :However, I cannot follow the first example of the tutorial for anything.
rh :I went so far as to download the tutorial package, and install it with the
rh :same exact paths it already has, and I'm getting the same results as when
rh :I was trying to follow along with my own data/.map file:  a single black
rh :vertical line, and nothing else, ie:
rh :
rh :  http://io.osuedc.org/terrasipBProjects/tutorial35/s1/s1ex1.html
rh :
rh :If anyone could provide any suggestions, I would really appreciate it.
rh :I'm sure its some stupid thing I'm overlooking.
rh :
rh :-rj
rh :osuedc systems developer
rh :
rh :--
rh :Information Center, n.:
rh :        A room staffed by professional computer people whose job it is to
rh :        tell you why you cannot have the information you require.
rh :
rh :rj hornsby . systems engineer . www.osuedc.org
rh :human and community resource development
rh :p 614 688 8761 . f 614 688 8762
rh :
rh :
rh :_______________________________________________
rh :Mapserver-users mailing list
rh :Mapserver-users at lists.gis.umn.edu
rh :http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
rh :
