[Mapserver-users] perl mapscript error
Lowell Filak lfilak at medinaco.org
Wed Jul 2 08:41:52 EDT 2003
I think this is moving in the right direction.
In http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptBuild35
there is a section referring to a private build that indicates that a
few changes need made to the Makefile.PL & you will also need to do a
"use lib" call before "use mapscript".
(Credits to mapsurfer).
HTH
Lowell
The following message was sent by "Aaron D. Hunt" <hunt at zedxinc.com> on
Tue, 1 Jul 2003 17:11:56 -0400.
> Is there something I am missind in this confg. to use local lib installs?
> ./configure --without-tiff --with-proj=/usr/home/mapserver/proj-4.4.7/
--wit
> h-gdal=/usr/home/mapserver/gdal-cvs-030626/bin/gdal-config
--with-ogr=/usr/h
> ome/mapserver/gdal-cvs-030626 --with-jpeg --with-wmsclient
--with-freetype=/
> usr/home/mapserver/freetype-2.1.4 --with-gd=/usr/home/mapserver/gd-2.0.15
> I am directing mapserver to use local install versions of libs, but it
seems
> to be picking its own to use. Is there a option to force the use of local
> libs
>  When I do the ldd mapserv I get
>         libgd.so.2 => not found
>         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40029000)
>         libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40048000)
>         libpng.so.2 => /usr/lib/libpng.so.2 (0x40087000)
>         libz.so.1 => /usr/lib/libz.so.1 (0x400aa000)
>         libproj.so.0 => /usr/local/lib/libproj.so.0 (0x400b8000)
>         libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x400e9000)
>         libcurl.so.2 => /usr/local/lib/libcurl.so.2 (0x40276000)
>         libssl.so.1 => /usr/lib/libssl.so.1 (0x4029b000)
>         libcrypto.so.1 => /usr/lib/libcrypto.so.1 (0x402c8000)
>         libdl.so.2 => /lib/libdl.so.2 (0x40385000)
>         libm.so.6 => /lib/libm.so.6 (0x4038a000)
>         libc.so.6 => /lib/libc.so.6 (0x403ac000)
>         libungif.so.4 => /usr/lib/libungif.so.4 (0x404e2000)
>         libtiff.so.3 => /usr/lib/libtiff.so.3 (0x404ea000)
>         libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
> (0x4052d000)
>         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
>         libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40570000)
> ----- Original Message -----
> From: "Lowell Filak" <lfilak at medinaco.org>
> To: "Aaron D. Hunt" <hunt at zedxinc.com>; "Lowell Filak"
> Sent: Tuesday, July 01, 2003 4:08 PM
> Subject: Re: [Mapserver-users] perl mapscript error
> > Check out
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptDebugging
> > and in particular the sections provided by Frank W. & Daniel M.
> > I think the important option to start with here is "ldd mapserv" to see
> > what the compilation is trying to use.
> > Lowell
> > Tue, 1 Jul 2003 15:13:56 -0400.
> > > I am using a local install of all the libraries. Is there a way to
tell
> > > which one it is trying to use.
> > > To: <mapserver-users at lists.gis.umn.edu>; <hunt at zedxinc.com>
> > > Sent: Tuesday, July 01, 2003 3:09 PM
> > > > Possibly an issue of library confusion?
> > > > Lowell
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0206/msg00385.html
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
