[Mapserver-users] converting e00 to postgis for use by
mapserver
Flavio Hendry
flavio at tydac.ch
Wed Jul 2 11:30:41 EDT 2003
hi heitzso
the newest version of FME (www.safe.com) supports PotGIS (and obvioulsy
supports all ESRI formats). If you need sophisticated translation FME
does it for you - however it a commercial product (but a good one!).
bet regards
flavio
-----Original Message-----
To: "'mapserver-users at lists.gis.umn.edu'" <mapserver-
users at lists.gis.umn.edu>
Date: Wed, 02 Jul 2003 08:29:10 -0400
Subject: [Mapserver-users] converting e00 to postgis for use by
mapserver
> I need to convert a number of e00 files into postgis for
> use by mapserver. I've tracked down, compiled, and installed
> the e00pg utility but it's not clear to me what options are required
> to
> generate a geometry field that mapserver can take advantage of,
> nor how to push it from a point orientation to line/polygon/whatever
> orientation.
> BTW, if it's not obvious, I'm just getting started with mapserver
> and I apologize if I'm not catching something obvious. I have
> loaded shape files into postgis and am able to define layers that
> I turn on and off, so I've got a start on things, but have much to
> learn. --> GOOD GENERIC GIS BOOK RECOMMENDATIONS?
> Thanks,
> Heitzso
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
