[Mapserver-users] Re: Compilation problems
Daniel Morissette
morissette at dmsolutions.ca
Tue Jul 8 13:15:46 EDT 2003
Jordy Keighan wrote:
> but why
> when i got to /htdocs/info.phtml
> do i get " MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=SHAPEFILE "
> when i installed 3.6.6 with proj
You should get "Version 3.6.6 .... SUPPORTS=PROJ ..." if you compiled
3.6.6 with PROJ.
It's quite likely that there is an old libmap.a in
/usr/local/lib/libmap.a on your system that would have been placed there
when you did 'make install' with a previous version. Delete this
libmap.a and recompile your mapserver and you should have the correct
version reported. Note that the 'make install' has been disabled in
3.6.6 and 4.0 to avoid this problem.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
