[Mapserver-users] Using WMS
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue Jul 8 17:32:39 EDT 2003
--------------070504090207030409000903
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I think the missing parameter in STYLES. Is it possible that the STYLES
parameter was missing in 3.6 ?
Daniel Morissette wrote:
>Jordy Keighan wrote:
>>I'm running mapserv 3.6.6
>>with maplab 2.0.1
>>when I try to apply a wms layer to my map i get this error
>>anyone as a idea why ?
>>Warning: MapServer Error in msDrawRaster(): Unrecognized or
>>unsupported image format in
>>/home/httpd/html/maplab/htdocs/common/wrapper/drawmap.php on line 387
>The short answer is that the remote WMS server didn't return a response
>in an image format that mapserver can understand. This can happen if
>your WMS layer's CONNECTION parameter is missing some required
>parameters and then the remote server returns an exception in XML format
>which would then confuse MapServer (I know it should try to make sense
>of XML exceptions, that's on the ToDo list, in the meantime, using
>exceptions INIMAGE is recommended).
>Perhaps if you sent your layer definition then we could help more. BTW,
>you write that you use MapLab, what did you do exactly in MapLab to get
>this error? Perhaps there is a problem with MapLab with your specific
>server?
>Daniel
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
I think the missing parameter in STYLES. Is it possible that the STYLES parameter
was missing in 3.6 ?<br>
<br>
Daniel Morissette wrote:<br>
<blockquote type="cite" cite="mid3F0B2FD9.50946C0E at dmsolutions.ca">
<pre wrap="">Jordy Keighan wrote:
</pre>
<blockquote type="cite">
<pre wrap="">I'm running mapserv 3.6.6
with maplab 2.0.1
</pre>
</blockquote>
<pre wrap=""><!---->
server?
Daniel
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Assefa Yewondwossen
Software Analyst
Email: <a class="moz-txt-link-abbreviated" href="mailto:assefa at dmsolutions.ca">assefa at dmsolutions.ca</a>
<a class="moz-txt-link-freetext" href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</a>
Fax: (613) 565-0925
</pre>
<br>
</body>
</html>
--------------070504090207030409000903--
