[Mapserver-users] Using WMS
Jordy Keighan jkeighan at cubewerx.com
Wed Jul 9 11:10:28 EDT 2003
--------------070000080904020408090907
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Yes, i'm getting this error by way of maplab
inside mapbrowser, i select a datastore, connect to
it and add a layer.
Is this error caused by maplab.
Daniel Morissette wrote:
>Jordy Keighan wrote:
>>I'm running mapserv 3.6.6
>>with maplab 2.0.1
>>when I try to apply a wms layer to my map i get this error
>>anyone as a idea why ?
>>Warning: MapServer Error in msDrawRaster(): Unrecognized or
>>unsupported image format in
>>/home/httpd/html/maplab/htdocs/common/wrapper/drawmap.php on line 387
>The short answer is that the remote WMS server didn't return a response
>in an image format that mapserver can understand.  This can happen if
>your WMS layer's CONNECTION parameter is missing some required
>parameters and then the remote server returns an exception in XML format
>which would then confuse MapServer (I know it should try to make sense
>of XML exceptions, that's on the ToDo list, in the meantime, using
>exceptions INIMAGE is recommended).
>Perhaps if you sent your layer definition then we could help more.  BTW,
>you write that you use MapLab, what did you do exactly in MapLab to get
>this error?  Perhaps there is a problem with MapLab with your specific
>server?
>Daniel
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <title></title>
</head>
<body>
Yes, i'm getting this error by way of maplab<br>
inside mapbrowser, i select a datastore, connect to<br>
it and add a layer.<br>
<br>
Is this error caused by maplab.<br>
<br>
Daniel Morissette wrote:<br>
<blockquote type="cite" cite="mid3F0B2FD9.50946C0E at dmsolutions.ca">
  <pre wrap="">Jordy Keighan wrote:
  </pre>
  <blockquote type="cite">
    <pre wrap="">I'm running mapserv 3.6.6
with maplab 2.0.1
    </pre>
  </blockquote>
  <pre wrap=""><!---->
server?
Daniel
  </pre>
</blockquote>
<br>
</body>
</html>
--------------070000080904020408090907--
