[Mapserver-users] Mapserver Bug
Zamil Murji Zamil.Murji at divestco.com
Tue Jul 15 13:18:42 EDT 2003
I have found my error. I was filling in the polygons lower down. If I fill the polygons lower down then everything I drew up above would not appear. My question is how do I make a layer transparent? My data comes from a shapefile. Can I use the OFFSITE tag or should I use something else. Here is a layer definition:
LAYER
# fast file
  NAME "counties"
  DATA boarders/counties
  STATUS off
  TYPE POLYGON
  MAXSCALE 29
  CLASS
   OUTLINECOLOR 0 0 0
   COLOR 84 247 168
  END
END
Thanks Zamil
-----Original Message-----
Sent: Tuesday, July 15, 2003 11:07 AM
To: Zamil Murji
Cc: Mapserver Users
Subject: RE: [Mapserver-users] Mapserver Bug
I'll forward the post to the list, someone else may be able
to help. I think more information on your setup will get
better input from the list.
Cheers
--- Zamil Murji <Zamil.Murji at divestco.com> wrote:
> Yup,
> I can show one layer at a time, but I can't get both on
> at the same time.
> From: Randy James [mailto:rjames57 at yahoo.com]
> Sent: Tuesday, July 15, 2003 10:54 AM
> To: Zamil Murji
> Hi
> Well hmm projection for the layers is correct?
> > the tiled shapefile location column does in fact
> contain
> > the full path to the tiled files. can you think of
> > anything else?
> > Sent: Monday, July 14, 2003 5:02 PM
> > To: Zamil Murji
> > the tiled shapefile location column should contain the
> > full
> > > Hi,
> > > What do you mean by this? Do you mean in the .map
> file
> > or
> > > the actual tiled shapefile location column?
> > > Thanks
> > > Zamil
> > > Sent: Monday, July 14, 2003 4:56 PM
> > > To: Zamil Murji
> > > Hi
> > > Do you have the full path, (rather than relative) in
> > the
> > > location column?
> > > > Hi Randy and company,
> > > > No i don't think i need tileitem because i am using
> > the
> > > > default of 'location'. I repeat that the first
> tiled
> > > > layer shows up but the ones underneath it do not.
> > > > Thanks
> > > > Zamil
> > > > Sent: Monday, July 14, 2003 4:48 PM
> > > > To: Zamil Murji
> > > > Cc: Mapserver-users at lists.gis.umn.edu
> > > > Subject: Re: [Mapserver-users] Mapserver Bug
> > > > Hi
> > > > Looks like you need the TILEITEM in your mapfile
> > > > It is the column that has the location of the tile
> in
> > > it
> > > > Cheers
> > > > > Hi Steve and the rest of the list,
> > > > > I found a bug with regards to mapserver and tiled
> > > > polygon
> > > > > layers. It seems that mapserver only displays the
> > > first
> > > > > tiled polygon layer in the .map file and doesn't
> > show
> > > > the
> > > > > tiled polygon layers below it. All other layers
> > show
> > > up
> > > > > just fine below the first tiled polygon layer.
> > > > > I've attached two images. One with the tile
> county
> > > > layer
> > > > > showing (above the township grid) and another
> with
> > > the
> > > > > township gird showing (above the county layer).
> > > > > Here are the two layer defs, please tell me if
> i'm
> > > > > missing something obvious:
> > > > > LAYER
> > > > >   NAME "counties"
> > > > >   TILEINDEX us_data/culture/countytileindex
> > > > >   STATUS off
> > > > >   TYPE POLYGON
> > > > >   CLASS
> > > > >    OUTLINECOLOR 0 0 0
> > > > >   end
> > > > > end
> > > > > LAYER
> > > > >   NAME "twp"
> > > > >   TILEINDEX us_data/townships/twptileindex
> > > > >   STATUS off
> > > > >   TYPE POLYGON
> > > > > #  MAXSCALE 25
> > > > >   CLASS
> > > > >    OUTLINECOLOR 183 178 178
> > > > > #OUTLINECOLOR 255 0 0
> > > > >   END
> > > > > END
> > > > > Zamil
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > Do you Yahoo!?
> > > > SBC Yahoo! DSL - Now only $29.95 per month!
> > > > http://sbc.yahoo.com
> > > Do you Yahoo!?
> > Do you Yahoo!?
