[Mapserver-users] [Fwd: Maplab for Oracle]
William A. Bronsema, C.E.T. bronsema at dmsolutions.ca
Fri Jul 18 06:24:20 EDT 2003
This is a multi-part message in MIME format.
--------------090308010701080306030601
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
Content-Type: message/rfc822;
 name="Maplab for Oracle"
Content-Disposition: inline;
 filename="Maplab for Oracle"
Return-Path: <utaitip at hotmail.com>
Received: from xcalibur.dmsolutions.ca (www2.dmsolutions.on.ca [209.217.116.146])
	by in2.magma.ca (Magma's Mail Server) with ESMTP id h6I3VUvc008948
	for <bronsema at magma.ca>; Thu, 17 Jul 2003 23:31:31 -0400
Received: from hotmail.com (bay8-f103.bay8.hotmail.com [64.4.27.103])
	by xcalibur.dmsolutions.ca (8.11.6/8.11.6) with ESMTP id h6I3VUe19536
	for <bronsema at dmsolutions.ca>; Thu, 17 Jul 2003 23:31:30 -0400
Received: from mail pickup service by hotmail.com with Microsoft SMTPSVC;
	 Thu, 17 Jul 2003 20:31:24 -0700
Received: from 202.28.38.11 by by8fd.bay8.hotmail.msn.com with HTTP;
	Fri, 18 Jul 2003 03:31:24 GMT
X-Originating-IP: [202.28.38.11]
X-Originating-Email: [utaitip at hotmail.com]
To: bronsema at dmsolutions.ca
Subject: Maplab for Oracle
Date: Fri, 18 Jul 2003 10:31:24 +0700
Mime-Version: 1.0
Content-Type: text/plain; format=flowed
Message-ID: <BAY8-F103SCO1HFOGRR000249c5 at hotmail.com>
X-OriginalArrivalTime: 18 Jul 2003 03:31:24.0399 (UTC) FILETIME=[10736FF0:01C34CDD]
Hello
    I have problem when I adding layer from oracle spatial
    I use oracle9i and I have recently downloaded Mapserver & MapLab
software and configured
with IIS as well as Apache web server. I could successfully able to run
the demo application of MapServer in both the  environments using the ESRI
shape file data. The application is able to do panning, zooming, querying,
layer control, etc. operations. Now as a part of second phase of the
project, I want to access the Oracle Spatial data from MapServer and
publish on browser. We made a trial but failed to achieve the objective. In
this regard, I coding the following map file
LAYER
    NAME "Bound"
    STATUS ON
    DATA "GEOM FROM BOUND USING SRID 90112"
    TYPE LINE
    CONNECTIONTYPE ORACLESPATIAL
    CONNECTION "admin/admin at GisMaejo"
    METADATA
      "DESCRIPTION"    "bounds"
    END
    #PROJECTION
    #  "init=epsg:23947"
    #END
    CLASS
      NAME "bounds"
      COLOR 255 153 153
      TEMPLATE "ttt_query.html"
    END
  END
I get an error: msDrawMap?()
Can you help me about:
1. How to get PHP_Mapscript.dll with oracle support?
2. Oracle9i already have OCI client dynamic link libraries (the DLLs)?
2. Could you elaborate the procedure for
setting up the configuration for oracle oci.
thank for advance
_________________________________________________________________
Protect your PC - get McAfee.com VirusScan Online
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
--------------090308010701080306030601--
