[Mapserver-users] MapServer on XP
Chip Hankley
Chip.Hankley at rmtinc.com
Tue Jul 22 10:43:32 EDT 2003
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=_8CD2A38B.1574398B
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: quoted-printable
Ryan...
=20
I so very rarely use the CGI version of MS. My skills are a bit rusty. As=
=20I recall, you have to point to the MapServer executable in your templa=
te file. If your "initiation" page (the one that says "click here to load=
=20the application") points to the correct location, but the template fil=
e does not, I think that you would experience this (i.e. your initial map=
=20would load, but all subsequent requests would not work). Make sure tha=
t in your template file, you're pointing to the MS executable. Also, note=
=20that it USED to be that the documentation (very unix/apache oriented) =
did not require you to put the trailing "exe" on the pointer to the file.=
=20I found that you HAVE to do this on windows.
=20
HTH.
=20
Chip
Outgoing messages, along with any attachments, are scanned for viruses at=
=20RMT prior to sending.
NOTICE--This email may contain confidential and privileged information=20
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,=
please contact the sender immediately and delete all copies.
Content-Type: text/html; charset=ISO-8859-1
Content-Description: HTML
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-=
1">
<META content=3D"MSHTML 6.00.2800.1126" name=3DGENERATOR></HEAD>
<BODY style=3D"MARGIN-TOP: 2px; FONT: 8pt Tahoma; MARGIN-LEFT: 2px">
<DIV><FONT size=3D2></FONT>Ryan...</DIV>
<DIV> </DIV>
<DIV>I so very rarely use the CGI version of MS. My skills are a bit rust=
y. As I=20
recall, you have to point to the MapServer executable in your template fi=
le. If=20
your "initiation" page (the one that says "click here to load the applica=
tion")=20
points to the correct location, but the template file does not, I think t=
hat you=20
would experience this (i.e. your initial map would load, but all subseque=
nt=20
requests would not work). Make sure that in your template file, you're po=
inting=20
to the MS executable. Also, note that it USED to be that the documentatio=
n (very=20
unix/apache oriented) did not require you to put the trailing "exe" on th=
e=20
pointer to the file. I found that you HAVE to do this on windows.</DIV>
<DIV> </DIV>
<DIV>HTH.</DIV>
<DIV> </DIV>
<DIV>Chip</DIV>
<P>Outgoing messages, along with any attachments, are scanned for vi=
ruses=20
at RMT prior to sending.=20
<HR>
NOTICE-- This email may contain confidential and privileged information f=
or the=20
sole use of the intended recipient. Any review or distribution by others =
is=20
strictly prohibited. If you are not the intended recipient, please c=
ontact=20
the sender immediately and delete all copies.=20
<P></P>
</BODY></HTML>
--=_8CD2A38B.1574398B--
