AW: [Mapserver-users] Problem with LINEITEM and CLASS NAME
Eduardo Spremolla
edspremolla at Antel.com.uy
Tue Jul 22 12:46:03 EDT 2003
try:
#-- LABELITEM "TOWERID"
CLASSITEM "SYMBOL"
CLASS
EXPRESSION /1/
#-- NAME "TOWERS"
SYMBOL 13
SIZE 11 # legend symbol size
COLOR 000 128 000 # legend symbol color - green
TEXT ([TOWERID]) #<------------------------------
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION AUTO
SIZE small
PARTIALS TRUE
BUFFER 2
END
END # CLASS
and got both in one layer
LALO
El mar, 22 de 07 de 2003 a las 12:45, Christina Biakowski (CCGIS)
escribió:
> Hello Roger,
> if you want to display Labels you have to choose "TYPE ANNOTATION". So you
> have to use two layers: one for displaying the towers as points "TYPE POINT"
> and one for labeling them.
> Hope this helps,
> Christina
> -----Ursprungliche Nachricht-----
> Von: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Roger
> Truesdale
> Gesendet: Dienstag, 22. Juli 2003 17:12
> An: mapserver-users at lists.gis.umn.edu
> Betreff: [Mapserver-users] Problem with LINEITEM and CLASS NAME
> I am running mapserv 3.6.6 with the following map that is listed below.
> Note the two lines marked by #-- in the TOWER layer. One is for the
> layer LINEITEM and the other for the class NAME.
> When BOTH of these lines are commented out, a map of county boundries
> appears with green circles for the tower locations.
> This part works fine, but I want to use the TowerId field values from
> the dbf file as labels for the tower locations. When I attempt to do
> this by uncommenting only the LINEITEM line, I just get a blank screen
> coming back with no error messages. I checked that the LINEITEM value
> TOWERID has the same case as in the dbf table. I also noticed that if I
> leave the LINEITEM line commented out and uncomment the class NAME line,
> then I also get a blank screen back. Can anyone see what I am doing
> wrong or what I may be missing?
> Thanks.
> -------------------------------------- MAP FILE
> # Start of map file
> NAME MAPSERV
> STATUS ON
> SIZE 600 600
> FONTSET symbols/fonts/fonts.list
> #SHADESET symbols/shade.sym
> #MARKERSET symbols/marker.sym
> #LINESET symbols/line.sym
> SYMBOLSET symbols/symbols_ms34.sym
> EXTENT 1292500.875 77778.96875 2746368.25 1233433.875
> #EXTENT 1223954.55020386 62738.1920192846 2817302.34231788
> 1247690.0222657
> UNITS FEET
> SHAPEPATH "D:\Inetpub\wwwroot\test\ShapeData"
> IMAGECOLOR 255 255 255
> # Start of web interface definition
> WEB
> HEADER "mapserv_header.html"
> TEMPLATE "mapserv.html"
> FOOTER "mapserv_footer.html"
> MINSCALE 1000
> MAXSCALE 15500000
> IMAGEPATH "d:\inetpub\wwwroot\test\temp\"
> IMAGEURL "/test/temp/"
> # LOG "D:\Inetpub\test\mapserv.log"
> # LOG "mapserv.log"
> END
> QUERYMAP
> SIZE 75 75
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of reference map
> #REFERENCE
> # IMAGE Graphics/reference.gif
> # EXTENT 1223954.55020386 62738.1920192846 2817302.34231788
> 1247690.0222657
> # SIZE 50 50
> # COLOR -1 -1 -1
> # OUTLINECOLOR 255 0 0
> #END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE Small
> COLOR 5 10 100
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 000 000 000
> LABEL
> COLOR 000 000 000
> SIZE Small
> END
> STYLE 1
> SIZE 20 2
> COLOR 000 000 000
> UNITS FEET
> INTERVALS 1
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of layer definitions
> LAYER
> NAME COUNTY
> TYPE POLYGON
> DATA county
> STATUS DEFAULT
> CLASS
> SYMBOL 3
> SIZE 4
> OUTLINECOLOR 128 128 128
> COLOR 255 255 128
> LABEL
> COLOR 0 0 0
> POSITION AUTO
> SIZE medium
> PARTIALS TRUE
> BUFFER 2
> END # LABEL OBJECT
> END # CLASS OBJECT
> HEADER "county_detail_header.html"
> FOOTER "county_detail_footer.html"
> QUERY
> TEMPLATE "county_detail.html"
> END
> END # end of layer object
> # Start of Tower Layer
> LAYER
> NAME TOWER
> TYPE Point
> STATUS DEFAULT
> DATA TOWER
> CLASSITEM "SYMBOL"
> CLASS
> EXPRESSION /1/
> #-- NAME "TOWERS"
> SYMBOL 13
> LABEL
> COLOR 0 0 0
> POSITION AUTO
> SIZE small
> PARTIALS TRUE
> BUFFER 2
> END
> END # CLASS
> END #LAYER
> END # End of Map File
> Roger Truesdale
> Interactive Site Architect
> eBusiness Solutions (f.k.a. i2Media)
> Contractual Services Group
> Usc Computer Services
> 1244 Blossom Street, Columbia, SC 29208
> Voice: (803) 777-7366 | (803) 777-1900 (fax)
> rogert at gwm.sc.edu | http://i2alliance.sc.edu
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
