[Mapserver-users] Performing queries with GDAL/OGR and PHPMapScript
Daniel Morissette morissette at dmsolutions.ca
Thu Jul 24 15:29:52 EDT 2003
Franck Martin wrote:
> What I see in the PHPMapscript is that the script returns the ID of the
> object selected. In the case of mysql ,postgis, DBF, the drivers are
> built inside php, so accessing the full record is not a problem.  But in
> the case of layers connected via OGR (like MapInfo tables), How do I
> access the full record?
> It seems that the mapserver is accessing all the fields of a record via
> OGR when it needs for instance to label objects. But it seems to me that
> this API does not exists in PHPMapScript.
You have access to all the attributes of a shape read via OGR using the
$shape->values[] array.  This is briefly explained in the PHP MapScript
docs:
----------------8<------------------
ShapeObj Class:
  Members:
    string  text
    int     classindex
    int     type      (read-only)
    int     numlines  (read-only)
    int     index     (read-only)
    int     tileindex (read-only)
    rectObj bounds    (read-only)
    int     numvalues (read-only)
    array   values    (read-only)
    The values array is an associative array with the attribute values for
    this shape.  It is set only on shapes obtained from layer->getShape().
    The key to the values in the array is the attribute name, e.g.
      $population = $shape->values["Population"];
---------------->8------------------
  DM Solutions Group              http://www.dmsolutions.ca/
