[Mapserver-users] Using MapServer as a general graphing engine
Tyler Mitchell
TMitchell at lignum.com
Mon Jul 28 15:02:25 EDT 2003
I'm thinking more along these lines:
- I have x,y data where these are two non-geographic values that I want to
graph. I have z which is the magnitude, count, etc. that I want to graph.
- Use a simple coordinate system to map the "location" of the x,y pairs and
draw the symbol based on the z value.
- z may be a value used as a radius for a circle or there may be a z- and
z+ which defines the vertical offsets of the extents of a bar/rectangle.
So I'm not so concerned with bringing in pre-made maps, as I am about
generating maps using non-spatial data. Of course, sometimes "z" may be
an image but I wasn't thinking that far ahead.
Tyler
Armin Burger <armin.burger at libero.it> wrote on 07/28/2003 12:53:53 PM:
> Tyler,
> I also found it sometimes desirable to have Mapserver create thematical
> maps with pie charts or bar charts, etc. I don't know how much work it
> might be to implement this. Maybe DM Solutions OWTChart could be somehow
> included?
> Another, probably a bit easier implementation, could be using MapScript
> combined with graphic modules/extensions for Perl or PHP, mainly based on
> the GD library. But as far as I know there is no possibility to include
> externally produced images and merge them on top of the map image. A
> question to the developers: would it be possible to have a Mapscript
> method that creates an imageObj from a file?
> This way one could create all the charts based on shapefile or database
> data with external graphic functions and merge these images with the map
> image using the existing 'pasteImage' method. For not too many charts the
> speed should be acceptable. For placing a chart exactly over a polygon a
> method to calculate the shape centroid would be helpful.
> Could this approach make sense?
> Armin
> > I know that a ton of web-based options exist for graphing and charting.
> > But very few seem to really understand spatial data and many have a
> > narrower scope of data sources than MapServer has.
> > Am I the only one interested in doing this or are you interested in
> doing
> > this as well. I see a few queries on related topics in the archives,
> but
> > very few responses. So I am writing now to gather a feel for the level
> of
> > interest that others on the list may have to do all sorts of graphing
> and
> > charting stuff all within MapServer's capabilities.
> > Tyler
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
