[Mapserver-users] Using MapServer as a general graphing engine
Daniel Morissette
morissette at dmsolutions.ca
Mon Jul 28 15:29:00 EDT 2003
Tyler Mitchell wrote:
> I'm thinking more along these lines:
> - I have x,y data where these are two non-geographic values that I want to
> graph. I have z which is the magnitude, count, etc. that I want to graph.
> - Use a simple coordinate system to map the "location" of the x,y pairs and
> draw the symbol based on the z value.
> - z may be a value used as a radius for a circle or there may be a z- and
> z+ which defines the vertical offsets of the extents of a bar/rectangle.
Actually, instead of a full integration with GDChart as suggested in my
previous message, we could add support in MapServer for symbols that
come from an URL, and this URL could contain [field] replacements,
similar to what we can do with query template URLs already.
So you could define a layer like this:
LAYER
CLASS
SYMBOL
"http://127.0.0.1/cgi-bin/owtchart?type=pie&numpts=3&vals=[VALUE_A]![VALUE_B]![VALUE_C]&xlabels=A!B!C&w=400&h=400"
END
END
This wouldn't be very fast, but would work fine for relatively small
number of symbols. When MapServer encounters a symbol name that starts
with http:// then it would do the field value replacements ([VALUE_A],
[VALUE_B] and [VALUE_C]), and then call the URL to download the symbol,
a chart in this case.
Another benefit of this approach is that you could link to about
anything that can dynamically generate images, not just charts.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
