[Mapserver-users] Using MapServer as a general graphing engine
steff
stephane.riff at cerene.fr
Tue Jul 29 04:17:43 EDT 2003
It's possible to do it with PHP using gd. i do it to add a logo on the
map before displaying it with phpmapscript.
W. Steph wrote:
> Just a thing :
>> But as far as I know there is no possibility to include
>> externally produced images and merge them on top of the map image.
> There's a very simple way !
> Just don't display the image with php, but use a java applet instead.
> Then, you'll can be able to do whatever you waqnt with the image,
> including adding other images. The only problem is that some colors
> can change a bit with some image types (I think png in an applet
> hasn't good colors but this may have change in latest versions).
> I'm using this method in order to let the user draw new polygon and
> multipoint layers on the map (and then I use geoserver WFS to send the
> data to the PostGis database) and it works very well.
> Adding charts and other dynamically generated images on a map
> (assuming you can calculate the good coordinates where to display the
> image) isn't a problem using java !
> I think you'll be able to test my java-based web application about the
> end of september, if you want to see it up and running :p
> Steph
> _________________________________________________________________
> MSN Messenger 6 http://g.msn.fr/FR1001/866 : plus de personnalisation,
> plus de fun pour vous et vos amis
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
