[Mapserver-users] lat lon
Ed McNierney ed at topozone.com
Mon Mar 3 09:47:01 EST 2003
Paul -
1. Please try to reply to the whole list, since someone else might be able to answer your question better or more quickly than I can.
2. What projection is that EPSG code describing?  I cannot find an EPSG code of 42304 in any of my EPSG tables - are you sure it's correct?  Does this projection have a common name?
3. Remember that what you've said (in this map file) is that the TIFF file is of the same projection as the output image.  As long as the georeference data for the TIFF matches the extents requested, you'll get a map.  If you're using a TIFF with world file it's very easy to have the projection completely wrong but still get a "correct" map.  But other layers won't project properly on to it.
4. Do you have MapServer built with PROJ support?
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
Sent: Monday, March 03, 2003 9:26 AM
To: Ed McNierney
Subject: Re: [Mapserver-users] lat lon
Hi Ed,
     My tiff is already displaying properly with (init=epsg:42304)  but
getting any lat/long data added is proving difficult to say the least.
Here is the first part of my map file with "Eman-sites" being the lat/long
data(last layer)
Paul
MAP
NAME "MAP OF CANADA"
  STATUS ON
  EXTENT -2200000 -712631 3072800 3840000
  SIZE 400 300
  #SHAPEPATH "./data/"
  SHAPEPATH "C:\2.0rc3\tutorial\data"
  SYMBOLSET "./etc/symbols.sym"
  FONTSET "./etc/fonts.txt"
  #IMAGETYPE PNG
  IMAGECOLOR 255 255 255
  UNITS METERS
  # Start of web interface definition
  WEB
    MINSCALE 2000000
    MAXSCALE 50000000
    IMAGEPATH "C:/temp/"
    IMAGEURL "/ms_tmp/"
  #  LOG "/tmp/gmap.log"
  END
  # Start of reference object (keymap)
  REFERENCE
    STATUS ON
    IMAGE "images/keymap.gif"
    SIZE 100 75
    COLOR -1 -1 -1
    OUTLINECOLOR 255 0 0
  END
  # Start of querymap object
  QUERYMAP
    COLOR 255 0 0
    STYLE HILITE
  END
  PROJECTION
    "init=epsg:42304"
  END
  # Start of legend object
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    TEMPLATE "ttt"
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Start of scalebar object
  SCALEBAR
    STATUS ON
    COLOR 255 255 255
    OUTLINECOLOR 0 0 0
    BACKGROUNDCOLOR 0 0 0
    UNITS kilometers
    INTERVALS 5
    SIZE 150 5
    LABEL
      SIZE SMALL
      COLOR 0 0 0
    END
  END
  LAYER
    NAME "bathymetry"
    STATUS ON
    DATA "bath_mapserver.tif"
    TYPE RASTER
    TEMPLATE "ttt.html"
  END
    NAME "Eman-sites"
    STATUS ON
    DATA "sites.shp"
    TYPE POINT
    UNITS METERS
    SIZEUNITS METERS
    LABELITEM "Name"
    TOLERANCE 5
    TOLERANCEUNITS PIXELS
    TRANSFORM TRUE
    TEMPLATE "ttt.html"
    PROJECTION
      "proj=longlat"
      "ellps=GRS80"
      "unit=dd"
      "no_defs"
    END
    CLASS
      NAME "site"
      SYMBOL 2
      COLOR 255 51 102
      SIZE 7
      MINSIZE 1
      MAXSIZE 100
    END
  END
----- Original Message -----
To: Paul Dymecki ; MapServer List (E-mail)
Sent: Monday, March 03, 2003 9:10 AM
Subject: RE: [Mapserver-users] lat lon
Paul -
You need to know all the details of your TIFF's projection, so you can
specify it completely.  Are you using one or two standard parallels for your
LCC?  You need the lat and lon of the origin, the scale factor, any false
easting & northing, etc.
    - Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Monday, March 03, 2003 9:05 AM
To: MapServer List (E-mail)
Subject: [Mapserver-users] lat lon
Hello all,
    I'm trying to display lat/long point data ontop of a tiff and was
wondering what should be the projection object for this layer would be?.
My map projection is lcc.
thx,
Paul
