Fw: [Mapserver-users] lat lon
Paul Dymecki millardymecki at sympatico.ca
Mon Mar 3 13:20:42 EST 2003
Hi Ed,
      I removed the point and also restricted my query to just pull 3 or 4
 records that looked good, but no luck.  It's strange that ESRI can view the
 shapes fine but other products like OpenEV and mapserverWorkbench can't.
 I'm thinking something in the format of the file is off so will start
 looking in that direction i guess.
 thanks in any case,
 Paul
> ----- Original Message -----
> From: "Ed McNierney" <ed at topozone.com>
> To: "Paul Dymecki" <millardymecki at sympatico.ca>
> Sent: Monday, March 03, 2003 12:52 PM
> Subject: RE: [Mapserver-users] lat lon
> Paul -
> Again, a guess - the "Credit River Watershed" data point seems to be bad
> data.  The longitude is positive and should be negative (I think).  I'm
> wondering if this is causing a projection problem since it's SO far from
the
> base point of the projection.  Can you test with this point
> corrected/removed?
> - Ed
> -----Original Message-----
> From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
> Sent: Monday, March 03, 2003 12:46 PM
> To: Ed McNierney
> Subject: Re: [Mapserver-users] lat lon
> Thanks a ton,
>     I just produced these shp files through mapscript(ie pulled the data
> from oracle).
> Paul,
> Sent: Monday, March 03, 2003 12:42 PM
> Paul -
> (off-list)
> If you can email me a copy of the shapefile I'll take a look at it.
> - Ed
> Sent: Monday, March 03, 2003 12:36 PM
> To: Ed McNierney
> Cc: Mapserver-users at lists.gis.umn.edu
> Hi Ed,
>      I actually just tested the layer in a mapfile on it's own and can't
> display, so think there might be something wrong with the data, although
it
> shows up fine in ESRI's arcExplorer.  Here is some output of doing a
shpdump
> on the shp file:
> Shapefile Type: Point # of Shapes: 73
> File Bounds: ( -139.450, 42.030,0,0)
> to ( 79.350, 82.130,0,0)
> Shape:0 (Point) nVertices=1, nParts=0
> Bounds:( -116.020, 50.570, 0, 0)
> to ( -116.020, 50.570, 0, 0)
> Shape:1 (Point) nVertices=1, nParts=0
> Bounds:( -81.240, 46.010, 0, 0)
> to ( -81.240, 46.010, 0, 0)
> Cc: <Mapserver-users at lists.gis.umn.edu>
> Sent: Monday, March 03, 2003 12:13 PM
> > Paul -
> > This is a bit of a shot in the dark, but in your PROJECTION block for
the
> lat/lon data, take out the "unit=dd" statement.  It's not needed (and
should
> be UNITS (plural) anyway) and might be breaking the projection.
> > You also don't seem to have a LAYER block surrounding the layer
definition
> for your lat/lon data - but that should give you a map file parsing error.
> Is your map file correct?
> > - Ed
> > Sent: Monday, March 03, 2003 11:59 AM
> > To: Ed McNierney
> > Yup i've it's supported so that's not the prob,
> > Paul
> > Sent: Monday, March 03, 2003 11:43 AM
> > > From a command prompt, run "mapserv -v" and look for "SUPPORTS=PROJ"
in
> > the message that's printed.
> > > - Ed
> > > Sent: Monday, March 03, 2003 11:42 AM
> > > To: Ed McNierney
> > > Hi Ed,
> > >     Sorry for a silly question but how would i know if i have proj
> support
> > > or not under windows?  I know i have proj support from mapscript (ie
my
> > > php_proj.dll is installed and running) but not sure of mapserver?
> > > thx,
> > > Paul
> > > Sent: Monday, March 03, 2003 9:47 AM
> > > Paul -
> > > 1. Please try to reply to the whole list, since someone else might be
> able
> > > to answer your question better or more quickly than I can.
> > > 2. What projection is that EPSG code describing?  I cannot find an
EPSG
> > code
> > > of 42304 in any of my EPSG tables - are you sure it's correct?  Does
> this
> > > projection have a common name?
> > > 3. Remember that what you've said (in this map file) is that the TIFF
> file
> > > is of the same projection as the output image.  As long as the
> > georeference
> > > data for the TIFF matches the extents requested, you'll get a map.  If
> > > you're using a TIFF with world file it's very easy to have the
> projection
> > > completely wrong but still get a "correct" map.  But other layers
won't
> > > project properly on to it.
> > > 4. Do you have MapServer built with PROJ support?
> > > - Ed
> > > Ed McNierney
> > > President and Chief Mapmaker
> > > TopoZone.com / Maps a la carte, Inc.
> > > 73 Princeton Street, Suite 305
> > > North Chelmsford, MA  01863
> > > ed at topozone.com
> > > (978) 251-4242
> > > Sent: Monday, March 03, 2003 9:26 AM
> > > To: Ed McNierney
> > > Hi Ed,
> > >      My tiff is already displaying properly with (init=epsg:42304)
but
> > > getting any lat/long data added is proving difficult to say the least.
> > > Here is the first part of my map file with "Eman-sites" being the
> lat/long
> > > data(last layer)
> > > Paul
> > > MAP
> > > NAME "MAP OF CANADA"
> > >   STATUS ON
> > >   EXTENT -2200000 -712631 3072800 3840000
> > >   SIZE 400 300
> > >   #SHAPEPATH "./data/"
> > >   SHAPEPATH "C:\2.0rc3\tutorial\data"
> > >   SYMBOLSET "./etc/symbols.sym"
> > >   FONTSET "./etc/fonts.txt"
> > >   #IMAGETYPE PNG
> > >   IMAGECOLOR 255 255 255
> > >   UNITS METERS
> > >   # Start of web interface definition
> > >   WEB
> > >     MINSCALE 2000000
> > >     MAXSCALE 50000000
> > >     IMAGEPATH "C:/temp/"
> > >     IMAGEURL "/ms_tmp/"
> > >   #  LOG "/tmp/gmap.log"
> > >   END
> > >   # Start of reference object (keymap)
> > >   REFERENCE
> > >     STATUS ON
> > >     IMAGE "images/keymap.gif"
> > >     SIZE 100 75
> > >     COLOR -1 -1 -1
> > >     OUTLINECOLOR 255 0 0
> > >   END
> > >   # Start of querymap object
> > >   QUERYMAP
> > >     COLOR 255 0 0
> > >     STYLE HILITE
> > >   END
> > >   PROJECTION
> > >     "init=epsg:42304"
> > >   END
> > >   # Start of legend object
> > >   LEGEND
> > >     STATUS ON
> > >     KEYSIZE 18 12
> > >     TEMPLATE "ttt"
> > >     LABEL
> > >       TYPE BITMAP
> > >       SIZE MEDIUM
> > >       COLOR 0 0 89
> > >     END
> > >   END
> > >   # Start of scalebar object
> > >   SCALEBAR
> > >     STATUS ON
> > >     COLOR 255 255 255
> > >     OUTLINECOLOR 0 0 0
> > >     BACKGROUNDCOLOR 0 0 0
> > >     UNITS kilometers
> > >     INTERVALS 5
> > >     SIZE 150 5
> > >     LABEL
> > >       SIZE SMALL
> > >       COLOR 0 0 0
> > >     END
> > >   END
> > >   LAYER
> > >     NAME "bathymetry"
> > >     STATUS ON
> > >     DATA "bath_mapserver.tif"
> > >     TYPE RASTER
> > >     TEMPLATE "ttt.html"
> > >   END
> > >     NAME "Eman-sites"
> > >     STATUS ON
> > >     DATA "sites.shp"
> > >     TYPE POINT
> > >     UNITS METERS
> > >     SIZEUNITS METERS
> > >     LABELITEM "Name"
> > >     TOLERANCE 5
> > >     TOLERANCEUNITS PIXELS
> > >     TRANSFORM TRUE
> > >     TEMPLATE "ttt.html"
> > >     PROJECTION
> > >       "proj=longlat"
> > >       "ellps=GRS80"
> > >       "unit=dd"
> > >       "no_defs"
> > >     END
> > >     CLASS
> > >       NAME "site"
> > >       SYMBOL 2
> > >       COLOR 255 51 102
> > >       SIZE 7
> > >       MINSIZE 1
> > >       MAXSIZE 100
> > >     END
> > >   END
> > > From: Ed McNierney
> > > To: Paul Dymecki ; MapServer List (E-mail)
> > > Sent: Monday, March 03, 2003 9:10 AM
> > > Paul -
> > > You need to know all the details of your TIFF's projection, so you can
> > > specify it completely.  Are you using one or two standard parallels
for
> > your
> > > LCC?  You need the lat and lon of the origin, the scale factor, any
> false
> > > easting & northing, etc.
> > >     - Ed
> > > Ed McNierney
> > > ed at topozone.com
> > > (978) 251-4242
> > > Sent: Monday, March 03, 2003 9:05 AM
> > > To: MapServer List (E-mail)
> > > Subject: [Mapserver-users] lat lon
> > > Hello all,
> > >     I'm trying to display lat/long point data ontop of a tiff and was
> > > wondering what should be the projection object for this layer would
be?.
> > > My map projection is lcc.
> > > thx,
> > > Paul
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
