[Mapserver-users] shapefile programming
Kieran J. Ames kames at keyspanenergy.com
Mon Mar 3 14:17:13 EST 2003
As I understand, mapscript only works on NT if you use php.
However, I'm wondering if I use a DOS window and invoke perl, will the mapscript.pm module then work?
...Kieran
Lowell Filak wrote:
> Sounds like a good case for an example so the perl mapscript program to do just that is at:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex15
> HTH
> Lowell F.
> The following message was sent by John Hagstrand <john.hagstrand at interageresearch.com> on Sun, 02 Mar 2003 13:01:21 -0600.
> > Hi,
> > I need a program or programmer to manipulate a Shapefile.
> > I want to pull the bounding box out of the SHP file and put it in the DBF
> > file.
> > You see what I mean?  I want to add four columns to the DBF file: north,
> > south, east and west.  And I want to populate those four fields to indicate
> > the boundary of each object.
> > Do you know of a utility program that will do this?  If not, do you know a
> > programmer who will write me such a utility program for a fee?
> > Thanks
> > John
> > John Hagstrand
> > Interage Research, Inc.
> > 847 838 5371
> > Software Development Consulting for Internet Content Management
> > We make knowledge accessible, useful, and relevant for everyone.
> > http://www.interageresearch.com
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
