[Mapserver-users] adding shp to mapfile / projection
Paul Dymecki
millardymecki at sympatico.ca
Mon Mar 3 15:58:14 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0166_01C2E19D.B2E21030
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Yes i think i've covered all the obvious, things, though you never know.
Here are my two scripts that query the db and create the shp and dbf files.
shp_ukpdate.php queries the db and eman_shp.php has supporting classes
thx,
Paul
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Paul Dymecki" <millardymecki at sympatico.ca>
Sent: Monday, March 03, 2003 3:38 PM
Subject: Re: [Mapserver-users] adding shp to mapfile / projection
> Paul Dymecki wrote:
> > Hi Daniel,
> > From talking to people i think i've narrowed it down to a problem
with
> > my shp file format. Any ways here is my current projection function,
create
> > point, and close() functions if you can see anything that's off?
> > thx,
> > Paul
> From reading the replies on the list this is probably the next logical
> thing to check, but without seeing your complete application including
> scripts and data nobody can confirm that.
> Did you make sure that you pass a valid shapefile type to the call to
> ms_newShapeFileObj()?
> BTW, please reply via the list, this will increase your chances of
> getting help.
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
Content-Type: application/octet-stream;
name="eman_shape.php"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="eman_shape.php"
<?php
* @descript: Contains underlying classes called from shp_update
* and shp_insert.
* @author Paul Dymecki
* @contact millardymecki at sympatico.ca=20
* @classes: Eman_Shape,Eman_Projection,Eman_Logger
*=20
if ( !extension_loaded("PHPPROJ") )
dl("php_proj.dll");
if ( !extension_loaded("MapScript") )
dl("php_Mapscript_36.dll");
=20
class Eman_Shape
var $shpFname;
var $dbfFname;
var $dbfFile;
var $shpFile;
var $oShp;
var $dBaseColumns;
function eman_shape($shpFilename)
$this-> dBaseColumns =3D
array(
array("Ename", "C" ,80),
array("Fname", "C", 80),
array("latitude", "N", 16, 5),
array("longitude", "N", 16,5),
array("pk_id", "N", 5,0)
=09
=20
$this-> shpFname =3D $shpFilename;
$this-> dbfFname =3D $this->shpFname.".dbf"; =20
=09
function createShape()
$this->shpFile =3D ms_newShapeFileObj($this->shpFname, MS_SHP_POINT);
$this->oShp =3D ms_newShapeObj(MS_SHAPE_POINT);
function openShape()
=20
=09
if(file_exists($this->shpFname.'.shp'))
$this->shpFile =3D ms_newShapeFileObj( $this->shpFname, -2);
return TRUE;
else=20
$message =3D "Error:The required shape file does not exist";
return FALSE;
//exit;
=20
=09
=20
function createPoint( $x, $y, $def )
// Create shape
$oPoint =3D ms_newPointObj();
$oPoint->setXY($x,$y); =20
$this->shpFile->addPoint($oPoint);
// Write attribute record
if( dbase_add_record($this->dbfFile, $def) =3D=3D FALSE )
$message =3D "Adding a record to dbase failed"; =20
$this->shpFile->free();
$oPoint->free();
return FALSE;
=20
$oPoint->free();
return TRUE;
=20
function createDbaseFile()
//IF FILE EXISTS DELETE IT
$file =3D $this->dbfFname;
if (file_exists($file))
{=20
=20
unlink($file);
=20
// database "definition"
//if (FALSE =3D=3D dbase_create($this->dbfFname, =
$this->dbaseColumns))
if (!dbase_create($this->dbfFname, $this->dBaseColumns))
return FALSE;
=09
else
return TRUE;
=09
function openDbase()
if (FALSE !=3D ($this->dbfFile =3D dbase_open( $this->dbfFname, 2)))
return TRUE;
else
return FALSE;=09
function close()
dbase_close($this->dbfFile);
fclose($this->dbfFile);
} =20
class Eman_Projection
var $lccXY;
function projectPoint($lat,$lon)
$dlat =3D doubleval($lat);
$dlon =3D doubleval($lon);
//project from geodetic coordinate degrees
$parms1[0] =3D "proj=3Dlonglat";
$parms1[1] =3D "ellps=3DGRS80";
$parms1[2] =3D "datum=3DNAD83"; =20
$parms1[3] =3D "no_defs";
$projLonLat =3D pj_init($parms1);
//project to lambert conical x,y
$parms2[0] =3D "proj=3Dlcc";
$parms2[1] =3D "ellps=3DGRS80";
$parms2[2] =3D "datum=3DNAD83";
$parms2[3] =3D "lat_0=3D 49.0";
$parms2[4] =3D "lon_0=3D -95.0";
$parms2[5] =3D "lat_1=3D 49.0";
$parms2[6] =3D "lat_2=3D 77.0";
$parms2[7] =3D "units=3Dm";
$projLCC =3D pj_init($parms2);
$this->lccXY =3D pj_transform($projLonLat, $projLCC, $dlon, $dlat,0 );
//$this->lccXY =3D array("u"=3D> 4,"v"=3D>5);
=09
pj_free($pj);
function getXYCoords()
{=20
if (0 !=3D array_count_values($this->lccXY) )
return($this->lccXY);=20
else
return 0;
class EmanLogger
var $toEmail;
var $logFile;
function emanLogger($email,$logFileName)
$this -> toEmail =3D $email;
$this -> logFile =3D $logFileName;
function logMessage($msg,$rec)
$d =3D date("F j, Y, g:i:s a");
$logMsg =3D $msg." ".$d." \n";
$logMsg.=3D $rec;
error_log($logMsg, 3, $this->logFile);
function sendErrorMail($subject,$msg,$rec,$myname)
$formattedMsg =3D "Error in script: ".$myname."<br>\n";
$formattedMsg.=3D "<p><b>".$msg."</b></p><br>\n";
$formattedMsg.=3D "Error while trying to insert the following =
record:<br>\n";
$formattedMsg.=3D $rec."<br>\n";
=20
$myemail =3D "webmaster at eman-rese.ca";
$contactname =3D "error";
$contactemail =3D "webmaster at rese.ca";
$myreplyemail =3D "webmaster at rese.ca";
$headers .=3D "MIME-Version: 1.0\r\n";=20
$headers .=3D "Content-type: text/html; charset=3Diso-8859-1\r\n";=20
$headers .=3D "From: ".$myname." <".$myemail.">\r\n"; =20
$headers .=3D "To: ".$contactname." <".$contactemail.">\r\n";=20
$headers .=3D "Reply-To: ".$myname." <$myreplyemail>\r\n";=20
$headers .=3D "X-Priority: 1\r\n";=20
$headers .=3D "X-MSMail-Priority: High\r\n";=20
mail($this->toEmail, $subject, $formattedMsg,$headers);
name="shp_update.php"
filename="shp_update.php"
<html> <head> <title>Shape Update Script</title> </head>
<body>
<?php
* @inputs: None
* @outputs: A new shp and dbf file with lat/lon having been =
projected to
* lcc.=20
* @descript: Database is queried for all records and new shp files =
are=20
* created.
*=20
//$cwd =3D getcwd();
include_once("eman_shape.php");
$TO_EMAIL =3D "millardymecki at sympatico.ca";
$MY_NAME =3D "shp_update.php";
$NO_RECORD =3D 0;
echo 'hello';
if (isset($_GET['shapefilepath'])) {
$shpFname =3D $_GET['shapefilepath'];
$SHP_FILE .=3D substr($shpFname,0, -4);//chop extension off
echo $SHP_FILE;
} else {
$SHP_FILE =3D 'c:\program files\apache =
group\apache2\htdocs\maplab-2.0rc3\tutorial\data\sites';
if (isset($_GET['logfilepath'])) {
$LOG_FILE =3D $_GET['logfilepath'];
} else {
$LOG_FILE =3D 'c:\shp_update.log';
echo($x." ".$y);
$oEmanLogger =3D new EmanLogger($TO_EMAIL,$LOG_FILE);
$oEmanProj =3D new Eman_Projection();
$oEmanShp =3D new Eman_Shape($SHP_FILE);
// -----------Begin Initialization Section -----------------
//------create new shape file
$oEmanShp->createShape();
echo "dbName ".$oEmanShp->shpFname;
//------open new shape file
if(FALSE =3D=3D ($oEmanShp->openShape()))
$message =3D "Error opening SHAPE file";
$oEmanLogger->sendErrorMail("Error in =
shp_update.php",$message,$NO_RECORD,$MY_NAME);
//------create new dbase file
if(FALSE =3D=3D ($oEmanShp->createDbaseFile()))
$message =3D "Error creating DBASE file:".$oEmanShp->dbfFname;
//------open dbase file
if(FALSE =3D=3D $oEmanShp->openDbase())
$message =3D "Error opening DBASE file";
$oEmanShp->close();
=20
// -----------End Initialization Section -----------------
// -----------Loop through the site table -----------------
$connect =3D odbc_connect('mon3', 'po8', 'po8', SQL_CUR_USE_ODBC);
$query =3D "SELECT pk_site, english_fullname, french_fullname, latitude, =
longitude FROM site, coordinates WHERE fk_coordinates =3D =
pk_coordinates";
$result =3D odbc_exec($connect, $query);
//Loop through and add records
while (odbc_fetch_row($result)) {
$recordToAdd =3D "";
$count =3D $count + 1;
echo "num recs".$count;
$frenchname =3D odbc_result($result, 3);
$englishname =3D odbc_result($result, 2);
$pk_site =3D odbc_result($result, 1);
$latitude =3D odbc_result($result, 4);
$longitude =3D odbc_result($result, 5);
$recordToAdd .=3D "PK_SITE_ID: ".$pk_site."\n";
$dbaseRecord =3D =
array($englishname,$frenchname,$latitude,$longitude,$pk_site);
=20
//currently not projecting just using lat/long vals
//here are some sample values
// 50.57 -60.02
// 46.01 -81.24
// 69.21 -108.06
$oEmanProj->projectPoint($latitude,$longitude);
$lccXY =3D $oEmanProj->getXYCoords();
=20
if($lccXY !=3D 0)
$x =3D ($lccXY["u"]);
$y =3D ($lccXY["v"]);
else
$message =3D "Error trying to project points";
shp_update.php",$message,$recordToAdd,$MY_NAME);
echo "<br>".$x."<br>";
echo $y."<br>";
*/=20
//i'm currently not using the projection just lat/lon values
if($oEmanShp->createPoint( $longitude, $latitude, $dbaseRecord))
$oEmanLogger->logMessage("Successfully added/updated Record at =
",$recordToAdd);
echo "Shapes Created.<BR>";
else
$oEmanLogger->logMessage("Unsuccessfully tried to add/update a =
Record at ",$recordToAdd);
$message =3D "Unknown Error in createPoint function";
$oEmanShp->close();
odbc_close($connect);
</body>
</html>
------=_NextPart_000_0166_01C2E19D.B2E21030--
