[Mapserver-users] adding shp to mapfile / projection
Paul Dymecki millardymecki at sympatico.ca
Mon Mar 3 16:37:31 EST 2003
Ok this one is strange,
     I'm able to display the shp file i created by moving it out of the
directory it's currently in.  Would this mean there's another shp file
that's conflicting with it?
Paul
----- Original Message -----
From: "Paul Dymecki" <millardymecki at sympatico.ca>
To: "Daniel Morissette" <morissette at dmsolutions.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 03, 2003 3:58 PM
Subject: Re: [Mapserver-users] adding shp to mapfile / projection
> Hi,
>    Yes i think i've covered all the obvious, things, though you never
know.
> Here are my two scripts that query the db and create the shp and dbf
files.
>  shp_ukpdate.php queries the db and eman_shp.php has supporting classes
> thx,
> Paul
> From: "Daniel Morissette" <morissette at dmsolutions.ca>
> To: "Paul Dymecki" <millardymecki at sympatico.ca>
> Sent: Monday, March 03, 2003 3:38 PM
> > Paul Dymecki wrote:
> > > Hi Daniel,
> > >      From talking to people i think i've narrowed it down to a problem
> with
> > > my shp file format.  Any ways here is my current projection function,
> create
> > > point, and close() functions if you can see anything that's off?
> > > thx,
> > > Paul
> > From reading the replies on the list this is probably the next logical
> > thing to check, but without seeing your complete application including
> > scripts and data nobody can confirm that.
> > Did you make sure that you pass a valid shapefile type to the call to
> > ms_newShapeFileObj()?
> > BTW, please reply via the list, this will increase your chances of
> > getting help.
> > Daniel
> >  Daniel Morissette               morissette at dmsolutions.ca
> >  DM Solutions Group              http://www.dmsolutions.ca/
