[Mapserver-users] adding shp to mapfile / projection
Ed McNierney
ed at topozone.com
Mon Mar 3 19:12:33 EST 2003
Paul -
It sounds like your IIS anonymous user account (usually
IUSR_<machinename>) does not have read permission on the directory you
originally used for this shapefile. Can you check that?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
Sent: Monday, March 03, 2003 6:31 PM
To: Daniel Morissette
Cc: MapServer List (E-mail)
Subject: Re: [Mapserver-users] adding shp to mapfile / projection
Hi All,
Well now i'm able to display my shp file in a map on it's own(had to
move my
data dir to the root of the c-drive) so now just have to get it working
with
my existing map file
Any hints or ideas would be appreciated,
Paul
MAP
NAME "MAP OF CANADA"
STATUS ON
#EXTENT -2.59456e+006 -712631 3.46736e+006 3.84e+006
EXTENT -2200000 -712631 3072800 3840000
SIZE 400 300
SHAPEPATH "c:/data-dir"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGECOLOR 255 255 255
TRANSPARENT OFF
UNITS METERS
INTERLACE ON
IMAGETYPE GIF
IMAGEQUALITY 75
WEB
MINSCALE 2e+006
MAXSCALE 5e+007
IMAGEPATH "C:/temp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
REFERENCE
STATUS ON
IMAGE "images/keymap.gif"
SIZE 100 75
EXTENT -2.2e+006 -712631 3.0728e+006 3.84e+006
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
PROJECTION
"init=epsg:42304"
END
LEGEND
STATUS OFF
TRANSPARENT FALSE
INTERLACE TRUE
POSITION LL
KEYSIZE 20 10
KEYSPACING 5 5
TEMPLATE "C:/Program Files/Apache
Group/Apache2/htdocs/maplab-2.0rc3/htdocs/mapbrowser/legend_template.htm
l"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 255 0 0
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
TRANSPARENT FALSE
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
INTERLACE TRUE
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
LAYER
NAME "bathymetry"
STATUS ON
DATA "bath_mapserver.tif"
TYPE RASTER
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
TEMPLATE "ttt.html"
END
LAYER
NAME "Eman-sites"
STATUS OFF
DATA "sites.shp"
TYPE POINT
UNITS METERS
SIZEUNITS METERS
LABELITEM "Name"
TOLERANCE 5
TRANSFORM TRUE
TEMPLATE "ttt.html"
CLASS
NAME "site"
SYMBOL 2
COLOR 255 51 102
SIZE 7
MINSIZE 1
MAXSIZE 100
END
END
END
----- Original Message -----
From: "Paul Dymecki" <millardymecki at sympatico.ca>
To: "Daniel Morissette" <morissette at dmsolutions.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 03, 2003 3:58 PM
> Hi,
> Yes i think i've covered all the obvious, things, though you never
know.
> Here are my two scripts that query the db and create the shp and dbf
files.
> shp_ukpdate.php queries the db and eman_shp.php has supporting
classes
> thx,
> Paul
> From: "Daniel Morissette" <morissette at dmsolutions.ca>
> To: "Paul Dymecki" <millardymecki at sympatico.ca>
> Sent: Monday, March 03, 2003 3:38 PM
> > Paul Dymecki wrote:
> > > Hi Daniel,
> > > From talking to people i think i've narrowed it down to a
problem
> with
> > > my shp file format. Any ways here is my current projection
function,
> create
> > > point, and close() functions if you can see anything that's off?
> > > thx,
> > > Paul
> > From reading the replies on the list this is probably the next
logical
> > thing to check, but without seeing your complete application
including
> > scripts and data nobody can confirm that.
> > Did you make sure that you pass a valid shapefile type to the call
to
> > ms_newShapeFileObj()?
> > BTW, please reply via the list, this will increase your chances of
> > getting help.
> > Daniel
> > Daniel Morissette morissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
