[Mapserver-users] adding shp to mapfile / projection
Paul Dymecki
millardymecki at sympatico.ca
Mon Mar 3 19:51:09 EST 2003
I'm on winXP but using apache though,
Paul
----- Original Message -----
To: "Paul Dymecki" <millardymecki at sympatico.ca>; "Daniel Morissette"
<morissette at dmsolutions.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 03, 2003 7:12 PM
Subject: RE: [Mapserver-users] adding shp to mapfile / projection
> Paul -
> It sounds like your IIS anonymous user account (usually
> IUSR_<machinename>) does not have read permission on the directory you
> originally used for this shapefile. Can you check that?
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
> Sent: Monday, March 03, 2003 6:31 PM
> To: Daniel Morissette
> Cc: MapServer List (E-mail)
> Subject: Re: [Mapserver-users] adding shp to mapfile / projection
> Hi All,
> Well now i'm able to display my shp file in a map on it's own(had to
> move my
> data dir to the root of the c-drive) so now just have to get it working
> with
> my existing map file
> Any hints or ideas would be appreciated,
> Paul
> MAP
> NAME "MAP OF CANADA"
> STATUS ON
> #EXTENT -2.59456e+006 -712631 3.46736e+006 3.84e+006
> EXTENT -2200000 -712631 3072800 3840000
> SIZE 400 300
> SHAPEPATH "c:/data-dir"
> SYMBOLSET "./etc/symbols.sym"
> FONTSET "./etc/fonts.txt"
> IMAGECOLOR 255 255 255
> TRANSPARENT OFF
> UNITS METERS
> INTERLACE ON
> IMAGETYPE GIF
> IMAGEQUALITY 75
> WEB
> MINSCALE 2e+006
> MAXSCALE 5e+007
> IMAGEPATH "C:/temp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> END
> REFERENCE
> STATUS ON
> IMAGE "images/keymap.gif"
> SIZE 100 75
> EXTENT -2.2e+006 -712631 3.0728e+006 3.84e+006
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> MINBOXSIZE 3
> MAXBOXSIZE 0
> MARKER 0
> MARKERSIZE 0
> END
> QUERYMAP
> STATUS OFF
> SIZE -1 -1
> COLOR 255 0 0
> STYLE HILITE
> END
> PROJECTION
> "init=epsg:42304"
> END
> LEGEND
> STATUS OFF
> TRANSPARENT FALSE
> INTERLACE TRUE
> POSITION LL
> KEYSIZE 20 10
> KEYSPACING 5 5
> TEMPLATE "C:/Program Files/Apache
> Group/Apache2/htdocs/maplab-2.0rc3/htdocs/mapbrowser/legend_template.htm
> l"
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> OFFSET 0 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 255 0 0
> PARTIALS TRUE
> FORCE FALSE
> END
> END
> SCALEBAR
> STATUS ON
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 0 0 0
> TRANSPARENT FALSE
> UNITS KILOMETERS
> INTERVALS 5
> SIZE 150 5
> STYLE 0
> POSITION LL
> INTERLACE TRUE
> LABEL
> TYPE BITMAP
> SIZE SMALL
> OFFSET 0 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 0
> PARTIALS TRUE
> FORCE FALSE
> END
> END
> LAYER
> NAME "bathymetry"
> STATUS ON
> DATA "bath_mapserver.tif"
> TYPE RASTER
> UNITS METERS
> SIZEUNITS PIXELS
> TOLERANCE 3
> TOLERANCEUNITS PIXELS
> TEMPLATE "ttt.html"
> END
> LAYER
> NAME "Eman-sites"
> STATUS OFF
> DATA "sites.shp"
> TYPE POINT
> UNITS METERS
> SIZEUNITS METERS
> LABELITEM "Name"
> TOLERANCE 5
> TRANSFORM TRUE
> TEMPLATE "ttt.html"
> CLASS
> NAME "site"
> SYMBOL 2
> COLOR 255 51 102
> SIZE 7
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> From: "Paul Dymecki" <millardymecki at sympatico.ca>
> To: "Daniel Morissette" <morissette at dmsolutions.ca>
> Sent: Monday, March 03, 2003 3:58 PM
> > Hi,
> > Yes i think i've covered all the obvious, things, though you never
> know.
> > Here are my two scripts that query the db and create the shp and dbf
> files.
> > shp_ukpdate.php queries the db and eman_shp.php has supporting
> classes
> > thx,
> > Paul
> > From: "Daniel Morissette" <morissette at dmsolutions.ca>
> > Sent: Monday, March 03, 2003 3:38 PM
> > > Paul Dymecki wrote:
> > > > Hi Daniel,
> > > > From talking to people i think i've narrowed it down to a
> problem
> > with
> > > > my shp file format. Any ways here is my current projection
> function,
> > create
> > > > point, and close() functions if you can see anything that's off?
> > > > thx,
> > > > Paul
> > > From reading the replies on the list this is probably the next
> logical
> > > thing to check, but without seeing your complete application
> including
> > > scripts and data nobody can confirm that.
> > > Did you make sure that you pass a valid shapefile type to the call
> to
> > > ms_newShapeFileObj()?
> > > BTW, please reply via the list, this will increase your chances of
> > > getting help.
> > > Daniel
> > > Daniel Morissette morissette at dmsolutions.ca
> > > DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
