[Mapserver-users] adding shp to mapfile / projection
Ed McNierney ed at topozone.com
Mon Mar 3 19:54:22 EST 2003
OK - the issue doesn't change.  You need to know what user context your
anonymous Web visitors are using, and make sure that that user has
permission to read that shapefile.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242  Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
Sent: Monday, March 03, 2003 7:51 PM
To: Ed McNierney; Daniel Morissette
Cc: MapServer List (E-mail)
Subject: Re: [Mapserver-users] adding shp to mapfile / projection
I'm on winXP but using apache though,
Paul
----- Original Message -----
To: "Paul Dymecki" <millardymecki at sympatico.ca>; "Daniel Morissette"
<morissette at dmsolutions.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 03, 2003 7:12 PM
Subject: RE: [Mapserver-users] adding shp to mapfile / projection
> Paul -
> It sounds like your IIS anonymous user account (usually
> IUSR_<machinename>) does not have read permission on the directory you
> originally used for this shapefile.  Can you check that?
> - Ed
> Ed McNierney
> ed at topozone.com
> Sent: Monday, March 03, 2003 6:31 PM
> To: Daniel Morissette
> Hi All,
> Well now i'm able to display my shp file in a map on it's own(had to
> move my
> data dir to the root of the c-drive) so now just have to get it
working
> with
> my existing map file
> Any hints or ideas would be appreciated,
> Paul
> MAP
>   NAME "MAP OF CANADA"
>   STATUS ON
>   #EXTENT -2.59456e+006 -712631 3.46736e+006 3.84e+006
>   EXTENT -2200000 -712631 3072800 3840000
>   SIZE 400 300
>   SHAPEPATH "c:/data-dir"
>   SYMBOLSET "./etc/symbols.sym"
>   FONTSET "./etc/fonts.txt"
>   IMAGECOLOR 255 255 255
>   TRANSPARENT OFF
>   UNITS METERS
>   INTERLACE ON
>   IMAGETYPE GIF
>   IMAGEQUALITY 75
>   WEB
>     MINSCALE 2e+006
>     MAXSCALE 5e+007
>     IMAGEPATH "C:/temp/ms_tmp/"
>     IMAGEURL "/ms_tmp/"
>   END
>   REFERENCE
>     STATUS ON
>     IMAGE "images/keymap.gif"
>     SIZE 100 75
>     EXTENT -2.2e+006 -712631 3.0728e+006 3.84e+006
>     COLOR -1 -1 -1
>     OUTLINECOLOR 255 0 0
>     MINBOXSIZE 3
>     MAXBOXSIZE 0
>     MARKER 0
>     MARKERSIZE 0
>   END
>   QUERYMAP
>     STATUS OFF
>     SIZE -1 -1
>     COLOR 255 0 0
>     STYLE HILITE
>   END
>   PROJECTION
>     "init=epsg:42304"
>   END
>   LEGEND
>     STATUS OFF
>     TRANSPARENT FALSE
>     INTERLACE TRUE
>     POSITION LL
>     KEYSIZE 20 10
>     KEYSPACING 5 5
>     TEMPLATE "C:/Program Files/Apache
Group/Apache2/htdocs/maplab-2.0rc3/htdocs/mapbrowser/legend_template.htm
> l"
>     LABEL
>       TYPE BITMAP
>       SIZE MEDIUM
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 255 0 0
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
>   SCALEBAR
>     STATUS ON
>     COLOR 255 255 255
>     OUTLINECOLOR 0 0 0
>     BACKGROUNDCOLOR 0 0 0
>     TRANSPARENT FALSE
>     UNITS KILOMETERS
>     INTERVALS 5
>     SIZE 150 5
>     STYLE 0
>     POSITION LL
>     INTERLACE TRUE
>     LABEL
>       TYPE BITMAP
>       SIZE SMALL
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 0
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
>   LAYER
>     NAME "bathymetry"
>     STATUS ON
>     DATA "bath_mapserver.tif"
>     TYPE RASTER
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 3
>     TOLERANCEUNITS PIXELS
>     TEMPLATE "ttt.html"
>   END
>   LAYER
>     NAME "Eman-sites"
>     STATUS OFF
>     DATA "sites.shp"
>     TYPE POINT
>     UNITS METERS
>     SIZEUNITS METERS
>     LABELITEM "Name"
>     TOLERANCE 5
>     TRANSFORM TRUE
>     TEMPLATE "ttt.html"
>     CLASS
>       NAME "site"
>       SYMBOL 2
>       COLOR 255 51 102
>       SIZE 7
>       MINSIZE 1
>       MAXSIZE 100
>     END
>   END
> END
> From: "Paul Dymecki" <millardymecki at sympatico.ca>
> To: "Daniel Morissette" <morissette at dmsolutions.ca>
> Sent: Monday, March 03, 2003 3:58 PM
> > Hi,
> >    Yes i think i've covered all the obvious, things, though you
never
> know.
> > Here are my two scripts that query the db and create the shp and dbf
> files.
> >  shp_ukpdate.php queries the db and eman_shp.php has supporting
> classes
> > thx,
> > Paul
> > From: "Daniel Morissette" <morissette at dmsolutions.ca>
> > Sent: Monday, March 03, 2003 3:38 PM
> > > Paul Dymecki wrote:
> > > > Hi Daniel,
> > > >      From talking to people i think i've narrowed it down to a
> problem
> > with
> > > > my shp file format.  Any ways here is my current projection
> function,
> > create
> > > > point, and close() functions if you can see anything that's off?
> > > > thx,
> > > > Paul
> > > From reading the replies on the list this is probably the next
> logical
> > > thing to check, but without seeing your complete application
> including
> > > scripts and data nobody can confirm that.
> > > Did you make sure that you pass a valid shapefile type to the call
> to
> > > ms_newShapeFileObj()?
> > > BTW, please reply via the list, this will increase your chances of
> > > getting help.
> > > Daniel
> > >  Daniel Morissette               morissette at dmsolutions.ca
> > >  DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
