[Mapserver-users] adding shp to mapfile / projection
Paul Dymecki
millardymecki at sympatico.ca
Mon Mar 3 20:34:37 EST 2003
Hi Ed,
You are absolutely right, turning on the guest account on xp did the
trick.
thx,
Paul
----- Original Message -----
To: "Paul Dymecki" <millardymecki at sympatico.ca>; "Daniel Morissette"
<morissette at dmsolutions.ca>
Cc: "MapServer List (E-mail)" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, March 03, 2003 7:54 PM
Subject: RE: [Mapserver-users] adding shp to mapfile / projection
> OK - the issue doesn't change. You need to know what user context your
> anonymous Web visitors are using, and make sure that that user has
> permission to read that shapefile.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Paul Dymecki [mailto:millardymecki at sympatico.ca]
> Sent: Monday, March 03, 2003 7:51 PM
> To: Ed McNierney; Daniel Morissette
> Cc: MapServer List (E-mail)
> Subject: Re: [Mapserver-users] adding shp to mapfile / projection
> I'm on winXP but using apache though,
> Paul
> From: "Ed McNierney" <ed at topozone.com>
> Sent: Monday, March 03, 2003 7:12 PM
> > Paul -
> > It sounds like your IIS anonymous user account (usually
> > IUSR_<machinename>) does not have read permission on the directory you
> > originally used for this shapefile. Can you check that?
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > Sent: Monday, March 03, 2003 6:31 PM
> > To: Daniel Morissette
> > Hi All,
> > Well now i'm able to display my shp file in a map on it's own(had to
> > move my
> > data dir to the root of the c-drive) so now just have to get it
> working
> > with
> > my existing map file
> > Any hints or ideas would be appreciated,
> > Paul
> > MAP
> > NAME "MAP OF CANADA"
> > STATUS ON
> > #EXTENT -2.59456e+006 -712631 3.46736e+006 3.84e+006
> > EXTENT -2200000 -712631 3072800 3840000
> > SIZE 400 300
> > SHAPEPATH "c:/data-dir"
> > SYMBOLSET "./etc/symbols.sym"
> > FONTSET "./etc/fonts.txt"
> > IMAGECOLOR 255 255 255
> > TRANSPARENT OFF
> > UNITS METERS
> > INTERLACE ON
> > IMAGETYPE GIF
> > IMAGEQUALITY 75
> > WEB
> > MINSCALE 2e+006
> > MAXSCALE 5e+007
> > IMAGEPATH "C:/temp/ms_tmp/"
> > IMAGEURL "/ms_tmp/"
> > END
> > REFERENCE
> > STATUS ON
> > IMAGE "images/keymap.gif"
> > SIZE 100 75
> > EXTENT -2.2e+006 -712631 3.0728e+006 3.84e+006
> > COLOR -1 -1 -1
> > OUTLINECOLOR 255 0 0
> > MINBOXSIZE 3
> > MAXBOXSIZE 0
> > MARKER 0
> > MARKERSIZE 0
> > END
> > QUERYMAP
> > STATUS OFF
> > SIZE -1 -1
> > COLOR 255 0 0
> > STYLE HILITE
> > END
> > PROJECTION
> > "init=epsg:42304"
> > END
> > LEGEND
> > STATUS OFF
> > TRANSPARENT FALSE
> > INTERLACE TRUE
> > POSITION LL
> > KEYSIZE 20 10
> > KEYSPACING 5 5
> > TEMPLATE "C:/Program Files/Apache
> Group/Apache2/htdocs/maplab-2.0rc3/htdocs/mapbrowser/legend_template.htm
> > l"
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > OFFSET 0 0
> > BUFFER 0
> > MINDISTANCE -1
> > MINFEATURESIZE -1
> > COLOR 255 0 0
> > PARTIALS TRUE
> > FORCE FALSE
> > END
> > END
> > SCALEBAR
> > STATUS ON
> > COLOR 255 255 255
> > OUTLINECOLOR 0 0 0
> > BACKGROUNDCOLOR 0 0 0
> > TRANSPARENT FALSE
> > UNITS KILOMETERS
> > INTERVALS 5
> > SIZE 150 5
> > STYLE 0
> > POSITION LL
> > INTERLACE TRUE
> > LABEL
> > TYPE BITMAP
> > SIZE SMALL
> > OFFSET 0 0
> > BUFFER 0
> > MINDISTANCE -1
> > MINFEATURESIZE -1
> > COLOR 0 0 0
> > PARTIALS TRUE
> > FORCE FALSE
> > END
> > END
> > LAYER
> > NAME "bathymetry"
> > STATUS ON
> > DATA "bath_mapserver.tif"
> > TYPE RASTER
> > UNITS METERS
> > SIZEUNITS PIXELS
> > TOLERANCE 3
> > TOLERANCEUNITS PIXELS
> > TEMPLATE "ttt.html"
> > END
> > LAYER
> > NAME "Eman-sites"
> > STATUS OFF
> > DATA "sites.shp"
> > TYPE POINT
> > UNITS METERS
> > SIZEUNITS METERS
> > LABELITEM "Name"
> > TOLERANCE 5
> > TRANSFORM TRUE
> > TEMPLATE "ttt.html"
> > CLASS
> > NAME "site"
> > SYMBOL 2
> > COLOR 255 51 102
> > SIZE 7
> > MINSIZE 1
> > MAXSIZE 100
> > END
> > END
> > END
> > From: "Paul Dymecki" <millardymecki at sympatico.ca>
> > To: "Daniel Morissette" <morissette at dmsolutions.ca>
> > Sent: Monday, March 03, 2003 3:58 PM
> > > Hi,
> > > Yes i think i've covered all the obvious, things, though you
> never
> > know.
> > > Here are my two scripts that query the db and create the shp and dbf
> > files.
> > > shp_ukpdate.php queries the db and eman_shp.php has supporting
> > classes
> > > thx,
> > > Paul
> > > From: "Daniel Morissette" <morissette at dmsolutions.ca>
> > > Sent: Monday, March 03, 2003 3:38 PM
> > > > Paul Dymecki wrote:
> > > > > Hi Daniel,
> > > > > From talking to people i think i've narrowed it down to a
> > problem
> > > with
> > > > > my shp file format. Any ways here is my current projection
> > function,
> > > create
> > > > > point, and close() functions if you can see anything that's off?
> > > > > thx,
> > > > > Paul
> > > > From reading the replies on the list this is probably the next
> > logical
> > > > thing to check, but without seeing your complete application
> > including
> > > > scripts and data nobody can confirm that.
> > > > Did you make sure that you pass a valid shapefile type to the call
> > to
> > > > ms_newShapeFileObj()?
> > > > BTW, please reply via the list, this will increase your chances of
> > > > getting help.
> > > > Daniel
> > > > Daniel Morissette morissette at dmsolutions.ca
> > > > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
