[Mapserver-users] GDAL / GIF misunderstanding?
Doug Cates doug at moximedia.com
Tue Mar 4 14:01:19 EST 2003
Frank,
Thanks. I'll let you know if it works.
Doug
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, March 04, 2003 11:01 AM
To: Daniel Morissette
Cc: Doug Cates; Mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] GDAL / GIF misunderstanding?
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>>I could provide a patch for mapraster.c if you are interested.  Should
this
>>be rolled into a future 3.6.x?  Note, I did already ensure that GDAL would
>>be used if TIFF, PNG or JPEG were not configured, but for some reason the
>>same fix was not applied for GIF.
> Frank,
> If the same logic is already applied and working for the JPEG and PNG
> formats in 3.6.x then I think it would be a good idea to fix the GIF
> case the same way in the 3.6.x branch so if we ever release 3.6.5 then
> this fix will be part of it.
Daniel / Doug,
OK, at this point I have to admit that I am not very CVS-branch competent.
I have checked out 3.6.4 just fine and built it, and prepared the patch.
Do I just commit, and it automatically goes into the right branch?
I have attached the very simple patch (untested).
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
