[Mapserver-users] RH8 and GD
Arthur, John John.Arthur at T-Mobile.com
Wed Mar 5 08:24:56 EST 2003
I found the offending problem... pdflib (I used the pdflib-4.0.1-1.i386.rpm).  After compiling without "--with-pdflib" everything worked great.  I guess I'll have to compile pdflib from source.
-----Original Message-----
From: woodbri at swoodbridge.com [mailto:woodbri at swoodbridge.com]
Sent: Tuesday, March 04, 2003 7:01 PM
To: Arthur, John; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] RH8 and GD
Oh one more thing, make SURE you
rpm -e gd
rpm -e gd-devel
and any dependent rpms or you are likely going to pick up the wrong
includes or libs.
-Steve W.
On 4 Mar 2003 at 11:07, Arthur, John wrote:
> Here is a test script: Note if the output is changed to gif or jpeg it
> will work.
> <?php
> Header("Content-type: image/png");
> $image = imagecreate(300, 300);
> $red = ImageColorAllocate($image, 204, 0, 0);
> $white = ImageColorAllocate($image, 255, 255, 255);
> $green = ImageColorAllocate($image, 0, 150, 0);
> $black = ImageColorAllocate($image, 0, 0, 0);
> ImageFilledRectangle($image, 0, 0, 300, 300, $white);  // white
> background ImageRectangle($image, 10, 10, 290, 290, $red);  // red
> frame
> $points = array(
>   "0" => "40", 	// x1
>   "1" => "50", 	// y1
>   "2" => "20", 	// x2
>   "3" => "240", 	// y2
>   "4" => "60", 	// x3
>   "5" => "60", 	// y3
>   "6" => "240", 	// x4
>   "7" => "20", 	// y4
>   "8" => "50", 	// x5
>   "9" => "40", 	// y5
>   "10" => "10", 	// x6
>   "11" => "10", 	// y6
> $number = count($points) / 2;
> ImageString($image, 5, 15, 250, "There are $number points", $black);
> ImageFilledPolygon($image, $points, $number, $red);
> for ($i = 1; $i <= 5; $i++) {  // five fonts
>  $k = (($i * 10) + 70);
>  ImageString($image, $i, 90, $k, "PHP images", $green);
> imagepng($image);  // render image
> imagedestroy($image); // free memory
> Sent: Tuesday, March 04, 2003 1:26 PM
> Subject: Re: [Mapserver-users] RH8 and GD
> John,
> Can you post a simple script that does this so I can try it on my
> config.
> Thanks,
>   -Steve W.
> On 4 Mar 2003 at 9:31, Arthur, John wrote:
> > This is not only related to Mapscript, but anything related to gd
> > and php.  I have read and followed the
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RedHat8AndMapserver37
> > to a "T".  Everything compiles fine and normal php scripts run
> > great. But, every time I run a php script that outputs an image
> > using the gd library (jpgraph, mapscript, or gd examples) Apache
> > returns this error:
> > Server error!
> > The server encountered an internal error and was unable to complete
> > your request.
> > Error message:
> > Premature end of script headers: php
> > If you think this is a server error, please contact the webmaster
> > Error 500
> > localhost
> > Tue 04 Mar 2003 12:20:18 PM EST
> > Apache/2.0.40 (Red Hat Linux)
> > There is nothing in the logs except "Premature end of script
> > headers: php".  I have tried this with PHP 4.3.1 - GD 2.0.11 and PHP
> > 4.2.3 - GD 2.0.7, with the same results.  Does anybody have a clue
> > what the issue might be?  Is it related to Apache 2.0?  BTW, the
> > mapserv cgi using the Itasca demo works just great.
> > Thanks,
> > John Arthur
> > RF Technician
> > Office:   (757) 490-7221
> > Cellular: (757) 839-0021
> > Email: john.arthur at t-mobile.com
> > T-Mobile USA
> > Get more from life
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
