[Mapserver-users] Sending image to stdout under Apache
Lowell Filak lfilak at medinaco.org
Wed Mar 5 10:27:50 EST 2003
Hmmm...
I thought I replied back concerning that.?
Just do a:
print "Content-type: image/png\n\n";
system("cat junk.png");
and that will send the image to stdout/the browser.
HTH
Lowell F.
The following message was sent by Eric Bridger <eric at gomoos.org> on 05 Mar 2003 08:59:12 +0000.
> The list archives show that this came up last Dec.
> (http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0212/msg00265.html) and while a work around was suggested there was no solution to the problem given, so I was wondering if anyone else had run into this problem.
> I'm having a problem using Perl mapscript $img->saveImage(undef, ...),
> to send an image, PNG and/or JPEG, to the standard output under Apache.
> Running in /cgi-bin I have the following script:
> my $map = new mapscript::mapObj($ms_dir . "/test.map");
> my $ref_img = $map->drawReferenceMap();
> # This works fine:
> #$ref_img->saveImage("junk.png", $mapscript::MS_PNG,
> $map->{transparent}, $map->{interlace}, 0);
> print "HTTP/1.0 200 OK\n";
> print "Content-type: image/png\r\n\r\n";
> binmode STDOUT;
> # this produces no output on Apache's STDOUT
> $ref_img->saveImage("", $mapscript::MS_PNG, $map->{transparent},
> $ref_img->free();
> exit;
> >From the command line this script works as expected.  But when run under
> Apache/mod_perl  it's as if the C msSaveImage() stdout stream is
> pointing somewhere other than the Apache stdout (i.e. the client
> browser).
> The work around of course is to save a disk file and then print it, but
> the whole point of this is to avoid the temp. disk files.  I've noticed
> a significant increase in performance when using mapserv as an image
> engine rather then using temp disk files.
> Thanks.
> Eric
> Setup:
> Apache/1.3.26 (Unix)
> Mapserv 3.6.4
> mod_perl 1.22
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
