[Mapserver-users] MS 3.7 and RH 8 woes
Gerry Creager
gerry.creager at tamu.edu
Wed Mar 5 11:20:58 EST 2003
Lowell,
Thanks. It all helps, even if it's not fixing the problem. At least
I'm starting to get a better handle on this stuff!
This is is what I had:
my $shape = new shapeObj($mapscript::MS_SHAPE_LINE);
Replaced with:
my $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
And it yielded the same error. I'm sure it's someting fundamental. I'm
just _lost_ at this point.
TIA, gerry
Lowell Filak wrote:
> If you currently have something like:
> my $shape = new shapeObj(-1);
> try replacing it with:
> my $shape = new mapscript::shapeObj(-1);
> HTH
> Lowell F.
> The following message was sent by Gerry Creager N5JXS <gerry.creager at tamu.edu> on Wed, 05 Mar 2003 07:47:40 -0600.
>>Sorry for the newbie questions: I should have kept up with the
>>technology myself instead of letting a graduating grad student get ahead
>>of me!
>>I've got the nightly build from Sunday evening compiled, sans errors,
>>and installed per Steve Woodbridge's Wiki entry. That part seemed to go
>>great. Excellent step-by-step directions, no problems. I took no
>>shortcuts there to get anyting going.
>>However, perl mapscript is DOA. I'd tried a CVS load that didn't even
>>come close to allowing me to compile perl-mapsecript, thus the nightly
>>download, which at least allowed compilation. So that's working.
>>Now, however, when I attempt to run a perl script that calls
>>perl-mapscript, I get the following:
>>[root at vne-dhcp-047 mesonet]# ./makeshapefile.pl
>>Name "mapscript::MS_SHAPEFILE_POLYGON" used only once: possible typo at
>>./makeshapefile.pl line 22.
>>Name "mapscript::MS_SHAPE_LINE" used only once: possible typo at
>>./makeshapefile.pl line 175.
>>Can't locate object method "new" via package "shapefileObj" (perhaps you
>>forgot to load "shapefileObj"?) at ./makeshapefile.pl line 22.
>>makeshapefile.pl worked on 3.6.3 on a RH7.3 install with perl v5.8.0.
>>I've gotten XBase and DBD loaded, and mapscript installed in the
>>appropriate place.
>>If it helps, here's the output of mapserv -v:
>>[root at vne-dhcp-047 mesonet]# /var/www/cgi-bin/mapserv -v
>>MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
>>SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
>>INPUT=GDAL INPUT=SHAPEFILE
>>Any advice greatly appreciated!
>>Gerry
>>Gerry Creager -- gerry.creager at tamu.edu
>>Texas Mesonet -- AATLT, Texas A&M University
>>Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>>Page: 979.228.0173
>>Office: 903A Eller Bldg, TAMU, College Station, TX 77843
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Network Engineering -- AATLT, Texas A&M University
FAX: 979.847.8578 Pager: 979.228.0173
