[Mapserver-users] MS 3.7 and RH 8 woes
Lowell Filak lfilak at medinaco.org
Wed Mar 5 09:06:55 EST 2003
If you currently have something like:
my $shape = new shapeObj(-1);
try replacing it with:
my $shape = new mapscript::shapeObj(-1);
HTH
Lowell F.
The following message was sent by Gerry Creager N5JXS <gerry.creager at tamu.edu> on Wed, 05 Mar 2003 07:47:40 -0600.
> Sorry for the newbie questions:  I should have kept up with the
> technology myself instead of letting a graduating grad student get ahead
> of me!
> I've got the nightly build from Sunday evening compiled, sans errors,
> and installed per Steve Woodbridge's Wiki entry.  That part seemed to go
> great.  Excellent step-by-step directions, no problems.  I took no
> shortcuts there to get anyting going.
> However, perl mapscript is DOA. I'd tried a CVS load that didn't even
> come close to allowing me to compile perl-mapsecript, thus the nightly
> download, which at least allowed compilation.  So that's working.
> Now, however, when I attempt to run a perl script that calls
> perl-mapscript, I get the following:
> [root at vne-dhcp-047 mesonet]# ./makeshapefile.pl
> Name "mapscript::MS_SHAPEFILE_POLYGON" used only once: possible typo at
> ./makeshapefile.pl line 22.
> Name "mapscript::MS_SHAPE_LINE" used only once: possible typo at
> ./makeshapefile.pl line 175.
> Can't locate object method "new" via package "shapefileObj" (perhaps you
> forgot to load "shapefileObj"?) at ./makeshapefile.pl line 22.
> makeshapefile.pl worked on 3.6.3 on a RH7.3 install with perl v5.8.0.
> I've gotten XBase and DBD loaded, and mapscript installed in the
> appropriate place.
> If it helps, here's the output of mapserv -v:
> [root at vne-dhcp-047 mesonet]# /var/www/cgi-bin/mapserv -v
> MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> Any advice greatly appreciated!
> Gerry
> Gerry Creager -- gerry.creager at tamu.edu
> Texas Mesonet -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
> Page: 979.228.0173
> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
