[Mapserver-users] documentation bug (was Re: projecting a point
in PHP MapScript)
Chris Black
cblack at CalAcademy.Org
Wed Mar 5 14:21:18 EST 2003
--------------080907020309020502020005
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Ok, I've stepped up to 3.7, which I downloaded as
mapserver-3.7-win32-php4.3.0-gd2.zip from
http://www2.dmsolutions.ca/mapserver/dl/ (since I'm on Windows, I'm
trying to avoid doing any compilation myself).
The behavior has changed somewhat; I now get an explicit failed return
code and an error message. I'm still not succeeding. Is there any way
to get a more explicit error message about why the projection is
failing? Is there a different 3.7 binary and libraries I should try?
Thanks.
-- Chris
my code:
1 <?php
2
3 dl('php_mapscript_37.dll');
4
5 $outproj =
ms_newProjectionObj("proj=utm,zone=10,datum=NAD27,ellps=clrk66,units=m,no_defs,north");
6 $inproj = ms_newProjectionObj("proj=longlat,ellps=clrk66");
7
8 $crab_here = ms_newpointobj();
9 $crab_here->setXY(38.20527700, -122.37277700);
10 $retval = $crab_here->project($inproj, $outproj);
11 if ($retval == MS_SUCCESS) {print("Succeeded. ");} else
{print("Failed. ");}
12 print(" x is ");
13 print($crab_here->x);
14 print("; y is ");
15 print($crab_here->y);
16 ?>
output with error message:
Warning: MapServer Error in : in c:\inetpub\scripts\debug_projection.php
on line 10
Failed. x is 38.205277; y is -122.372777
metadata describing the map I want to print the point onto, and from
which I am therefore taking the definition of $outproj:
SPATIAL_REFERENCE_INFORMATION
Horizontal_Coordinate_System_Definition
Planar
Grid_Coordinate_System
Grid_Coordinate_System_Name: Universal Transverse Mercator
Universal_Transverse_Mercator:
UTM_Zone_Number: 10
Transverse_Mercator
Scale_Factor_at_Central_Meridian: implied
Longitude_of_Central_Meridian: implied
Latitude_of_Projection_Origin: implied
False_Easting: implied
False_Northing: implied
Planar_Coordinate_Information
Planar_Coordinate_Encoding_Method: Row and column
Coordinate_Representation:
Abscissa_Resolution: 30.0
Ordinate_Resolution: 30.0
Planar_Distance_Units: Meters
Geodetic_Model
Horizontal_Datum_Name: North American Datum 1927
Ellipsoid_Name: Clarke 1866
Semi-major_Axis: 6378206.4
Denominator_of_Flattening_Ratio: 294.98
Daniel Morissette wrote:
>Chris Black wrote:
>>Eric Bridger wrote:
>>>Chris,
>>>1) pointObj->project() does not return a point, it just reprojects the
>>>pointObj, so getting a null is not an error.
>>In that case, the online PHP class documentation should be modified.
>> The doc at
>>http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj
>>has this code snippet:
>Actually the 3.6 version "tries to" return a point but it's broken, it
>returns a point with an invalid internal poinObj reference, and the
>initial object is updated internally but the PHP wrapper is not, if you
>continue to play with the returned object you'll eventually end up with
>a crash. In 3.7 it won't return a point any more, instead it updates
>the point on which the project() method is called.
>I think your problem is simply that the project() method is broken in
>3.6 and cannot be relied upon. I'll see if I could backport the 3.7
>changes to 3.6, I just hoped that we could avoid that since very few
>people seemed to use those methods. The other option would be for you
>to use 3.7 in which the project() method works very well.
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title></title>
</head>
<body>
Ok, I've stepped up to 3.7, which I downloaded as mapserver-3.7-win32-php4.3.0-gd2.zip
from <a class="moz-txt-link-freetext" href="http://www2.dmsolutions.ca/mapserver/dl/">http://www2.dmsolutions.ca/mapserver/dl/</a> (since I'm on Windows, I'm
trying to avoid doing any compilation myself).<br>
<br>
The behavior has changed somewhat; I now get an explicit failed return code
and an error message. I'm still not succeeding. Is there any way to get
a more explicit error message about why the projection is failing? Is there
a different 3.7 binary and libraries I should try?<br>
<br>
Thanks.<br>
<br>
-- Chris<br>
<br>
my code:<br>
----------------<br>
1 <?php<br>
2<br>
3 dl('php_mapscript_37.dll'); <br>
4<br>
5 $outproj = ms_newProjectionObj("proj=utm,zone=10,datum=NAD27,ellps=clrk66,units=m,no_defs,north");<br>
6 $inproj = ms_newProjectionObj("proj=longlat,ellps=clrk66");<br>
7<br>
8 $crab_here = ms_newpointobj();<br>
9 $crab_here->setXY(38.20527700, -122.37277700);<br>
10 $retval = $crab_here->project($inproj, $outproj);<br>
11 if ($retval == MS_SUCCESS) {print("Succeeded. ");} else {print("Failed.
");}<br>
12 print(" x is ");<br>
13 print($crab_here->x);<br>
14 print("; y is ");<br>
15 print($crab_here->y);<br>
16 ?><br>
-------------------------<br>
output with error message:<br>
<br>
<b>Warning</b>: MapServer Error in : in <b>c:\inetpub\scripts\debug_projection.php</b>
on line <b>10</b><br>
Failed. x is 38.205277; y is -122.372777<b><br>
---------------------------------<br>
</b>metadata describing the map I want to print the point onto, and from
which I am therefore taking the definition of $outproj:<br>
SPATIAL_REFERENCE_INFORMATION<br>
<br>
<br>
<br>
Horizontal_Coordinate_System_Definition<br>
<br>
Planar<br>
<br>
Grid_Coordinate_System<br>
<br>
Grid_Coordinate_System_Name: Universal Transverse Mercator<br>
<br>
Universal_Transverse_Mercator:<br>
<br>
UTM_Zone_Number: 10<br>
<br>
Transverse_Mercator<br>
<br>
Scale_Factor_at_Central_Meridian: implied<br>
<br>
Longitude_of_Central_Meridian: implied<br>
<br>
Latitude_of_Projection_Origin: implied<br>
<br>
False_Easting: implied<br>
<br>
False_Northing: implied<br>
<br>
Planar_Coordinate_Information<br>
<br>
Planar_Coordinate_Encoding_Method: Row and column<br>
<br>
Coordinate_Representation:<br>
<br>
Abscissa_Resolution: 30.0<br>
<br>
Ordinate_Resolution: 30.0<br>
<br>
Planar_Distance_Units: Meters<br>
<br>
Geodetic_Model<br>
<br>
Horizontal_Datum_Name: North American Datum 1927<br>
<br>
Ellipsoid_Name: Clarke 1866<br>
<br>
Semi-major_Axis: 6378206.4<br>
<br>
Denominator_of_Flattening_Ratio: 294.98<br>
<br>
<b><br>
</b><br>
<br>
<br>
Daniel Morissette wrote:<br>
<blockquote type="cite" cite="mid3E6526D6.1EF85B21 at dmsolutions.ca">
<pre wrap="">Chris Black wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Eric Bridger wrote:
</pre>
<pre wrap="">Chris,
</pre>
</blockquote>
<pre wrap="">In that case, the online PHP class documentation should be modified.
The doc at
<a class="moz-txt-link-freetext" href="http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj">http://mapserver.gis.umn.edu/doc36/phpmapscript-class-guide.html#proj</a>
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080907020309020502020005--
