[Mapserver-users] documentation bug (was Re: projecting a point
in PHP MapScript)
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 5 14:27:03 EST 2003
Chris Black wrote:
> Ok, I've stepped up to 3.7, which I downloaded as
> mapserver-3.7-win32-php4.3.0-gd2.zip from
> http://www2.dmsolutions.ca/mapserver/dl/ (since I'm on Windows, I'm
> trying to avoid doing any compilation myself).
> The behavior has changed somewhat; I now get an explicit failed return
> code and an error message. I'm still not succeeding. Is there any way
> to get a more explicit error message about why the projection is
> failing? Is there a different 3.7 binary and libraries I should try?
Chris,
Generally speaking it is hard to get meaningful error messages from PROJ.4
explaining failure, but a good start is to do testing with the "cs2cs"
commandline program distributed with PROJ.4.
cs2cs +proj=latlong +ellps=clrk66 +to +proj=utm +zone=10 +datum=NAD27 \
+ellps=clrk66 +units=m +no_defs +north
38.2052770 -122.37277700
* * 0.000
Well, this fails because you have X and Y backwards. I assume you want to
translate the location 122.372777E, 38.2052770N? Even though the coordinate
system is called latlong (longlat also works) the order is latitude,longitude.
Second, you provide a datum definition for one coordinate system but not
the other. This seems to cause a problem. If I change to just listing
the ellipses things seem OK:
cs2cs +proj=latlong +ellps=clrk66 +to +proj=utm +zone=10 +ellps=clrk66 +units=m +no_defs +north
-122.372777 38.2052770
554916.29 4228571.08 0.000
So, try correcting these problems in your script.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
