[Mapserver-users] Help Request / datum shifts
Ed McNierney ed at topozone.com
Thu Mar 6 11:16:26 EST 2003
Chip -
Thanks; that's why I was confused.  You don't need to recompile the PROJ library code, but you do need to build those files from the distribution.  Once you've built them, however, I think just copying them into the right directory will do it.
	- Ed
-----Original Message-----
From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
Sent: Thursday, March 06, 2003 10:47 AM
To: Ed McNierney; Kieran J. Ames
Cc: MapServer List (E-mail)
Subject: RE: [Mapserver-users] Help Request / datum shifts
> Actually, I'm now not sure about whether you'll need to
> recompile or not.
I think you do have to compile. ED, the files that you provided me when I
was having trouble with this were some type of binary files. For instance,
what is available from the PROJ4 site are the text based datum shift files:
ALASKA
CONUS
...etc.
After compilation, there will be binary files of the same name, with the LLA
extension:
ALASKA.LLA
CONUS.LLA
...etc.
I think what I found was that simply having the text files in there was not
enough... you had to have the LLAs (which you can only get by compiling).
FWIW, these files have to be in two places if you're using BOTH cgi and
php-mapscript. CGI looks for them in C:\proj\nad, and PHP-MapScript looks
for them in c:\proj. I'm sure you could re-configure this at compile time,
but, I typically use the pre-compiled binaries.
Kieran, if you want, I can zip up my PROJ directory and e-mail it to you. In
my opinion, we should put up a compiled version of the PROJ directory on the
web site for windows users.
Chip
