[Mapserver-users] Graticule support not working?
Ed McNierney ed at topozone.com
Thu Mar 6 15:24:10 EST 2003
Daniel -
I found the same code, and moved the GRID block up to the layer level.  Now MapServer hangs....
	- Ed
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Thursday, March 06, 2003 3:22 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Graticule support not working?
Ed McNierney wrote:
> I decided to play around with the new graticule code, and I can't get it to work.  I get a loadfeature (): Unknown identifier error for the "GRID" line below:
I get the same error as you on Linux with the latest 3.7 source from CVS
when using your layer defn.  Note that I have not played with the grid
stuff yet so I can only confirm that I get the same error as you but I
can't help.
Well, maybe I can... ;)  Looking at mapfile.c, the loadFeature()
function doesn't expect a GRID element, it seems that the GRID/END block
should be at the layer level.
 Daniel Morissette               morissette at dmsolutions.ca
 DM Solutions Group              http://www.dmsolutions.ca/
