[Mapserver-users] Graticule support not working?
Brent Fraser bfraser at geoanalytic.com
Thu Mar 6 18:46:20 EST 2003
Hmm.  I've got code from around Feb 12 -17 ish that works ok, produces a
grid.  The GRID structure is at the FEATURE level.
Brent Fraser
----- Original Message -----
To: "Daniel Morissette" <morissette at dmsolutions.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 06, 2003 1:24 PM
Subject: RE: [Mapserver-users] Graticule support not working?
> Daniel -
> I found the same code, and moved the GRID block up to the layer level.
Now MapServer hangs....
> - Ed
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Thursday, March 06, 2003 3:22 PM
> To: Ed McNierney
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Graticule support not working?
> Ed McNierney wrote:
> > I decided to play around with the new graticule code, and I can't get it
to work.  I get a loadfeature (): Unknown identifier error for the "GRID"
line below:
> I get the same error as you on Linux with the latest 3.7 source from CVS
> when using your layer defn.  Note that I have not played with the grid
> stuff yet so I can only confirm that I get the same error as you but I
> can't help.
> Well, maybe I can... ;)  Looking at mapfile.c, the loadFeature()
> function doesn't expect a GRID element, it seems that the GRID/END block
> should be at the layer level.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
