[Mapserver-users] CGI returns malformed headers
Brantley Hobbs bhobbs at itos.uga.edu
Fri Mar 7 17:13:18 EST 2003
Well, one thing that I did differently between my workstation and the
development server was to place those libraries in their own directory
and just add it to the path.  This worked well enough for the
mapserver.exe -v command to work properly, so I assumed that this was
OK.  I'm just a little suspicious of dropping a bunch of unknown
libraries into system32.
When I tried to copy them over, it complained that xmlparse.dll was in
use when it tried to copy over it.
Anyway, I'll sort that out and reply back when I know something.  I'll
have to reboot in order to free up the original xmlparse.dll so that I
can overwrite it.  <sigh>  Windows is such a pain.
B.
> -----Original Message-----
> From: Martin, Daniel [mailto:DMartin at erac.com]
> Sent: Friday, March 07, 2003 5:09 PM
> To: Brantley Hobbs; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] CGI returns malformed headers
> Usually this is caused by problems with the libraries that
> should be installed into C:\WINNT\SYSTEM32.  Either:
> A) You didn't install the libraries.
> B) You have an older version of the libraries than your build needs.
> C) You installed libwww_dll.zip when you actually needed
> ms35_libs.dll.
> Go to http://mapserver.gis.umn.edu/win32binaries.html, find
> the build you chose, and download the appropriate library.
> Extract into C:\Winnt\SYSTEM32 and chose YES if it asks to overwrite.
> Hope that helps,
> -Dan Martin
> > From: Brantley Hobbs [mailto:bhobbs at itos.uga.edu]
> > Sent: Friday, March 07, 2003 3:43 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] CGI returns malformed headers
> > All,
> > I'm new to the mapserver app and I've run into a problem I
> > can't seem to
> > figure out.
> > On my personal workstation, I'm able to run the demo app just fine.
> > When I moved the app to our development server for more
> general use, I
> > find that the webserver is now reporting that the CGI isn't
> returning
> > a complete set of headers.  I've tried the CGI with both Apache and
> > IIS, with the same results.  I know that the demo app works,
> > because I set up
> > the directory structure on my workstation to be identical to the
> > directory structure on the server and everything works fine there.
> > I have verified that the server (both Apache and IIS) has
> write access
> > to the image output directory.
> > Here is a mapserver.exe -v output: C:\Inetpub\scripts>mapserv.exe -v
> > MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP
> > SUPPORTS=P
> > ROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF
> > INPUT=EPPL7
> > INPUT=JPEG INPUT=OGR INPUT=SHAPEFILE
> > I have also tried to add a line to the .map file to have
> some sort of
> > logging mechanism, but the CGI isn't even creating the log.
> > Can someone give me some pointers here?
> > Thanks,
> > Brantley Hobbs
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
