[Mapserver-users] CGI returns malformed headers
Martin, Daniel DMartin at erac.com
Fri Mar 7 17:09:25 EST 2003
Usually this is caused by problems with the libraries that should be
installed into C:\WINNT\SYSTEM32.  Either:
A) You didn't install the libraries.
B) You have an older version of the libraries than your build needs.
C) You installed libwww_dll.zip when you actually needed ms35_libs.dll.
Go to http://mapserver.gis.umn.edu/win32binaries.html, find the build you
chose, and download the appropriate library.  Extract into C:\Winnt\SYSTEM32
and chose YES if it asks to overwrite.
Hope that helps,
-Dan Martin
> -----Original Message-----
> From: Brantley Hobbs [mailto:bhobbs at itos.uga.edu]
> Sent: Friday, March 07, 2003 3:43 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] CGI returns malformed headers
> All,
> I'm new to the mapserver app and I've run into a problem I
> can't seem to
> figure out.
> On my personal workstation, I'm able to run the demo app just fine.
> When I moved the app to our development server for more general use, I
> find that the webserver is now reporting that the CGI isn't
> returning a
> complete set of headers.  I've tried the CGI with both Apache and IIS,
> with the same results.  I know that the demo app works,
> because I set up
> the directory structure on my workstation to be identical to the
> directory structure on the server and everything works fine there.
> I have verified that the server (both Apache and IIS) has write access
> to the image output directory.
> Here is a mapserver.exe -v output:
> C:\Inetpub\scripts>mapserv.exe -v
> MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=P
> ROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF
> INPUT=EPPL7
> INPUT=JPEG INPUT=OGR INPUT=SHAPEFILE
> I have also tried to add a line to the .map file to have some sort of
> logging mechanism, but the CGI isn't even creating the log.
> Can someone give me some pointers here?
> Thanks,
> Brantley Hobbs
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
