[Mapserver-users] CGI returns malformed headers
Brantley Hobbs
bhobbs at itos.uga.edu
Fri Mar 7 17:36:38 EST 2003
Yep, they're required to be in system32.
Works fine now.
I wonder how big the exe would be if those were statically
compiled......
Thanks all,
Brantley
> -----Original Message-----
> From: Martin, Daniel [mailto:DMartin at erac.com]
> Sent: Friday, March 07, 2003 5:29 PM
> To: Brantley Hobbs; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] CGI returns malformed headers
> AFAIK putting dll libraries in the path on Windows isn't
> enough. I believe they must be in C:\WINNT\System32. But,
> if you prove me wrong I'd love to know about it.
> -Dan
> > From: Brantley Hobbs [mailto:bhobbs at itos.uga.edu]
> > Sent: Friday, March 07, 2003 4:13 PM
> > To: Martin, Daniel; mapserver-users at lists.gis.umn.edu
> > Well, one thing that I did differently between my
> workstation and the
> > development server was to place those libraries in their
> own directory
> > and just add it to the path. This worked well enough for the
> > mapserver.exe -v command to work properly, so I assumed
> that this was
> > OK. I'm just a little suspicious of dropping a bunch of unknown
> > libraries into system32.
> > When I tried to copy them over, it complained that
> xmlparse.dll was in
> > use when it tried to copy over it.
> > Anyway, I'll sort that out and reply back when I know
> something. I'll
> > have to reboot in order to free up the original
> xmlparse.dll so that I
> > can overwrite it. <sigh> Windows is such a pain.
> > B.
> > > Sent: Friday, March 07, 2003 5:09 PM
> > > Usually this is caused by problems with the libraries that
> > > should be installed into C:\WINNT\SYSTEM32. Either:
> > > A) You didn't install the libraries.
> > > B) You have an older version of the libraries than your
> build needs.
> > > C) You installed libwww_dll.zip when you actually needed
> > > ms35_libs.dll.
> > > Go to http://mapserver.gis.umn.edu/win32binaries.html, find
> > > the build you chose, and download the appropriate library.
> > > Extract into C:\Winnt\SYSTEM32 and chose YES if it asks to
> > overwrite.
> > > Hope that helps,
> > > -Dan Martin
> > > > Sent: Friday, March 07, 2003 3:43 PM
> > > > To: mapserver-users at lists.gis.umn.edu
> > > > Subject: [Mapserver-users] CGI returns malformed headers
> > > > All,
> > > > I'm new to the mapserver app and I've run into a
> problem I can't
> > > > seem to figure out.
> > > > On my personal workstation, I'm able to run the demo app
> > just fine.
> > > > When I moved the app to our development server for more
> > > general use, I
> > > > find that the webserver is now reporting that the CGI isn't
> > > returning
> > > > a complete set of headers. I've tried the CGI with both
> > Apache and
> > > > IIS, with the same results. I know that the demo app works,
> > > > because I set up the directory structure on my
> workstation to be
> > > > identical to the directory structure on the server and
> everything
> > > > works fine there.
> > > > I have verified that the server (both Apache and IIS) has
> > > write access
> > > > to the image output directory.
> > > > Here is a mapserver.exe -v output:
> > C:\Inetpub\scripts>mapserv.exe -v
> > > > MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > > OUTPUT=WBMP
> > > > SUPPORTS=P
> > > > ROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > INPUT=TIFF
> > > > INPUT=EPPL7
> > > > INPUT=JPEG INPUT=OGR INPUT=SHAPEFILE
> > > > I have also tried to add a line to the .map file to have
> > > some sort of
> > > > logging mechanism, but the CGI isn't even creating the log.
> > > > Can someone give me some pointers here?
> > > > Thanks,
> > > > Brantley Hobbs
> > > > _______________________________________________
> > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
