[Mapserver-users] Reading DBF files with PHP dbase extension?
woodbri at swoodbridge.com
Fri Mar 7 21:27:25 EST 2003
Many thanks to those the responded.
So, here is an update on what I found.
It seems like the first dbf file or two that I tried to read using
the php dbase extension may have some kind of problem. Using the code
below I was able to read other dbf files without a problem and use
dbase_get_record_with_names().
It is not clear why I had problems with the first two files as they
seem fine when using dbfdump (the C program that came with shapelib)
and they work fine otherwise with mapserver, and they work fine with
the Perl Xbase.pm module. This problem is still a small mystery that
will have to wait.
So back to the original project ...
-Steve W.
On 7 Mar 2003 at 8:07, woodbri at swoodbridge.com wrote:
> OK, this is getting a little bit off topic, but I am trying to do a
> query then fetch attributes from the DBF using the PHP dbase
> extension.
> I'm using older versions of PHP-4.2.2 it test this on with code like:
> <?php
> ### try to read a dbf file
> $dbh = @ dbase_open('/data/mdata/us/us_pop2k.dbf', READ_ONLY) or
> die("Could not open '/data/mdata/nhpn.dbf' for read.");
> $num_fields = dbase_numfields ($dbh);
> $num_rows = dbase_numrecords($dbh);
> print "<br>num_fields = $num_fields\n";
> print "<br>num_rows = $num_rows\n";
> print "<pre>";
$rr = dbase_get_record_with_names($dbh, 1);
for (reset($rr); $k = key($rr); next($rr)) {
print "$k = ".$rr[$k]."\n";
> for ($i=1; $i <= 10; $i++) {
> $row = dbase_get_record($dbh, $i);
> printf("%7d: %s\n", $i, join("|", $row));
> print "</pre>";
> dbase_close($dbh);
> It seems to work, but I get varying results with different DBF files.
> And if I try to use dbase_get_record_with_names() the script dies on
> that call without any errors.
> I'll try this again on PHP-4.3.1 tonight, but wondering if anyone else
> has tried going this with or without success?
> Thanks,
> Steve W.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
