[Mapserver-users] Reading DBF files with PHP dbase extension?
woodbri at swoodbridge.com
Fri Mar 7 08:07:32 EST 2003
OK, this is getting a little bit off topic, but I am trying to do a
query then fetch attributes from the DBF using the PHP dbase
extension.
I'm using older versions of PHP-4.2.2 it test this on with code like:
<?php
### try to read a dbf file
$dbh = @ dbase_open('/data/mdata/us/us_pop2k.dbf', READ_ONLY) or
die("Could not open '/data/mdata/nhpn.dbf' for read.");
$num_fields = dbase_numfields ($dbh);
$num_rows = dbase_numrecords($dbh);
print "<br>num_fields = $num_fields\n";
print "<br>num_rows = $num_rows\n";
print "<pre>";
for ($i=1; $i <= 10; $i++) {
$row = dbase_get_record($dbh, $i);
printf("%7d: %s\n", $i, join("|", $row));
print "</pre>";
dbase_close($dbh);
It seems to work, but I get varying results with different DBF files.
And if I try to use dbase_get_record_with_names() the script dies on
that call without any errors.
I'll try this again on PHP-4.3.1 tonight, but wondering if anyone
else has tried going this with or without success?
Thanks,
Steve W.
