[Mapserver-users] A QUERY only mapfile, PHP/Mapscript, get not results
woodbri at swoodbridge.com
Sat Mar 8 16:14:03 EST 2003
Dylan,
Thank you for taking a look, but no cigar :)
On 8 Mar 2003 at 12:23, Dylan Keon wrote:
> Not sure if this is it, but try setting the last parameter in
> queryByPoint() to -1 instead of 1.0. If you want to use the TOLERANCE
> setting in the layer definition, the last parameter in queryByPoint()
> should be <= 0. By setting it to 1.0, you're saying you want to find
> features within 1.0 ground units of where you clicked. That may not
> be enough tolerance to find features near your point (?).
I tried that originally, the changed it to 1.0 which for another
test. In this case the world_countries_shp is a polygon layer and I
checked it out in ArcExplorer and the point is inside the polygon. So
that should not be a problem.
I changed the map file so the layer has:
TOLERANCE 1000000
TOLERANCEUNITS FEET
and is didn't make a difference.
> Also, why do you have your printf statement printing both
> $layer->tolerance and $layer-toleranceunits to the TOLERANCE line? I
> thought the TOLERANCE line just accepted the tolerance level, and to
> set toleranceunits you need a separate TOLERANCEUNITS line.
The printf statements were just there to verify the contents of the
map and layer objects to make sure I was getting reasonable results.
> --Dylan
> woodbri at swoodbridge.com wrote:
> > Hi all,
> > My brain must have gone on vacation or something, because I have
> > what I thought should be a trivial example to put together and I can
> > not seem to get it to work!
> > Built a simple php script to do a query of a query only mapfile and
> > print the results. I have included below the results, query.map,
> > t2.php
> > So, does anyone have any ideas on what stupid thing I have
> > overlooked. Oh, the world_countries_shp file is good and in units
> > DD. I have tried this with 12 different layers all with the same
> > results. I just stripped that down to this simple example. And I
> > have tried it on php-4.3.1 and MS-3.7_dev with the same results.
> > -Steve W.
> > ------------------------------ results
> > query point = (-71.3940, 42.6140)
> > LAYER country, 0
> > STATUS 1
> > TYPE 5
> > SHAPEPATH /data/mdata/
> > TILEINDEX
> > DATA world/world_countries_shp
> > TEMPLATE dummy
> > TOLERANCE 3.000 6
> > Warning: MapServer Error in msQueryByPoint(): No matching record(s)
> > found.
> > in /home/httpd/html/maptools/rgeo/t2.php on line 29
> > ret=1
> > ---------------------------------- query.map
> > MAP
> > NAME "EXAMPLE"
> > STATUS ON
> > EXTENT -180.0 -14.8 -51.75 113.4
> > SHAPEPATH "/data/mdata/"
> > UNITS DD
> > LAYER # this is a polygon layer
> > NAME "country"
> > TYPE QUERY
> > STATUS ON
> > DATA "world/world_countries_shp"
> > TEMPLATE "dummy"
> > METADATA
> > "DESCRIPTION" "World Countries"
> > "RESULT_FIELDS" "NAME CAPITAL CONTINENT"
> > END
> > END
> > END
> > ---------------------------------- t2.php
> > <?php
> > dl("php4.2.2_mapscript-20020904.so"); # mapserver 3.6.2
> > define(MAPFILE, '/data/mdata/query.map');
> > $point = ms_newPointObj();
> > $point->setXY(-71.394, 42.614);
> > print "<pre>\n";
> > printf("query point = (%.4f, %.4f)\n\n", $point->x, $point->y);
> > $map = ms_newMapObj(MAPFILE) or
> > die("Can't create mapObj using " . MAPFILE);
> > $map->preparequery();
> > $shapepath = $map->shapepath;
> > for ($i=0; $i<$map->numlayers; $i++) {
> > $layer = $map->getLayer($i);
> > $layer->set('status', MS_ON);
> > printf("LAYER %s, %d\n", $layer->name, $layer->index);
> > printf(" STATUS %d\n TYPE %d\n", $layer->status,
> > $layer->type); printf(" SHAPEPATH %s\n", $shapepath); printf("
> > TILEINDEX %s\n", $layer->tileindex); printf(" DATA %s\n",
> > $layer->data); printf(" TEMPLATE %s\n", $layer->template);
> > printf(" TOLERANCE %.3f %d\n", $layer->tolerance, $layer-
> >>toleranceunits);
> > $ret = $layer->queryByPoint($point, MS_MULTIPLE, 1.0);
> > print "ret=$ret\n";
> > if ($ret == MS_SUCCESS) {
> > for ($j=0; $j<$layer->getNumResults(); $j++) {
> > $result = $layer->getResult($j);
> > printf("lay=%d, res=%d, si=%d, ti=%d, ci=%d\n",
> > $i, $j, $result->shapeindex, $result->tileindex,
> > $result->classindex);
> > phpinfo();
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
