[Mapserver-users] A QUERY only mapfile, PHP/Mapscript, get not results
woodbri at swoodbridge.com woodbri at swoodbridge.com
Sat Mar 8 16:34:37 EST 2003
Ah Ha!
I got it. There seems to be a bug or documentation problem. The
template MUST be inside a CLASS ... END block, contrary to the
documentation.
So the mapfile must look like :
MAP
  NAME "EXAMPLE"
  STATUS ON
  EXTENT -180.0 -14.8 -51.75 113.4
  SHAPEPATH "/data/mdata/"
  UNITS DD
  LAYER
    NAME "country"
    TYPE QUERY
    STATUS ON
    DATA "world/world_countries_shp"
    CLASS
      TEMPLATE "dummy"
    END
    TOLERANCE 1000000
    TOLERANCEUNITS FEET
    METADATA
      "DESCRIPTION"    "World Countries"
      "RESULT_FIELDS"  "NAME CAPITAL CONTINENT"
    END
  END
END
OK, back to your regular programming.
-Steve W.
On 8 Mar 2003 at 16:14, woodbri at swoodbridge.com wrote:
> Dylan,
> Thank you for taking a look, but no cigar :)
> On 8 Mar 2003 at 12:23, Dylan Keon wrote:
> > Not sure if this is it, but try setting the last parameter in
> > queryByPoint() to -1 instead of 1.0.  If you want to use the
> > TOLERANCE setting in the layer definition, the last parameter in
> > queryByPoint() should be <= 0.  By setting it to 1.0, you're saying
> > you want to find features within 1.0 ground units of where you
> > clicked.  That may not be enough tolerance to find features near
> > your point (?).
> I tried that originally, the changed it to 1.0 which for another test.
> In this case the world_countries_shp is a polygon layer and I checked
> it out in ArcExplorer and the point is inside the polygon. So that
> should not be a problem.
> I changed the map file so the layer has:
>     TOLERANCE 1000000
>     TOLERANCEUNITS FEET
> and is didn't make a difference.
> > Also, why do you have your printf statement printing both
> > $layer->tolerance and $layer-toleranceunits to the TOLERANCE line?
> > I thought the TOLERANCE line just accepted the tolerance level, and
> > to set toleranceunits you need a separate TOLERANCEUNITS line.
> The printf statements were just there to verify the contents of the
> map and layer objects to make sure I was getting reasonable results.
> > --Dylan
> > > Hi all,
> > > My brain must have gone on vacation or something, because I have
> > > what I thought should be a trivial example to put together and I
> > > can not seem to get it to work!
> > > Built a simple php script to do a query of a query only mapfile
> > > and print the results. I have included below the results,
> > > query.map, t2.php
> > > So, does anyone have any ideas on what stupid thing I have
> > > overlooked. Oh, the world_countries_shp file is good and in units
> > > DD. I have tried this with 12 different layers all with the same
> > > results. I just stripped that down to this simple example. And I
> > > have tried it on php-4.3.1 and MS-3.7_dev with the same results.
> > > -Steve W.
> > > ------------------------------ results
> > > query point = (-71.3940, 42.6140)
> > > LAYER country, 0
> > >   STATUS 1
> > >   TYPE 5
> > >   SHAPEPATH /data/mdata/
> > >   TILEINDEX
> > >   DATA world/world_countries_shp
> > >   TEMPLATE dummy
> > >   TOLERANCE 3.000 6
> > > Warning:  MapServer Error in msQueryByPoint(): No matching
> > > record(s) found.
> > >  in /home/httpd/html/maptools/rgeo/t2.php on line 29
> > > ret=1
> > > ---------------------------------- query.map
> > > MAP
> > >   NAME "EXAMPLE"
> > >   STATUS ON
> > >   UNITS DD
> > >   LAYER   # this is a polygon layer
> > >     NAME "country"
> > >     TYPE QUERY
> > >     STATUS ON
> > >     TEMPLATE "dummy"
> > >     METADATA
> > >     END
> > >   END
> > > END
> > > ---------------------------------- t2.php
> > > <?php
> > > dl("php4.2.2_mapscript-20020904.so"); # mapserver 3.6.2
> > > define(MAPFILE, '/data/mdata/query.map');
> > > $point = ms_newPointObj();
> > > $point->setXY(-71.394, 42.614);
> > > print "<pre>\n";
> > > printf("query point = (%.4f, %.4f)\n\n", $point->x, $point->y);
> > > $map = ms_newMapObj(MAPFILE) or
> > >     die("Can't create mapObj using " . MAPFILE);
> > > $map->preparequery();
> > > $shapepath = $map->shapepath;
> > > for ($i=0; $i<$map->numlayers; $i++) {
> > >     $layer = $map->getLayer($i);
> > >     $layer->set('status', MS_ON);
> > >     printf("LAYER %s, %d\n", $layer->name, $layer->index);
> > >     printf("  STATUS %d\n  TYPE %d\n", $layer->status,
> > >     $layer->type); printf("  SHAPEPATH %s\n", $shapepath);
> > >     printf(" TILEINDEX %s\n", $layer->tileindex); printf("  DATA
> > >     %s\n", $layer->data); printf("  TEMPLATE %s\n",
> > >     $layer->template); printf("  TOLERANCE %.3f %d\n",
> > >     $layer->tolerance, $layer-
> > >>toleranceunits);
> > >     $ret = $layer->queryByPoint($point, MS_MULTIPLE, 1.0);
> > >     print "ret=$ret\n";
> > >     if ($ret == MS_SUCCESS) {
> > >         for ($j=0; $j<$layer->getNumResults(); $j++) {
> > >             $result = $layer->getResult($j);
> > >             printf("lay=%d, res=%d, si=%d, ti=%d, ci=%d\n",
> > >                 $i, $j, $result->shapeindex, $result->tileindex,
> > >                 $result->classindex);
> > > phpinfo();
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
