[Mapserver-users] projection problem
Ed McNierney
ed at topozone.com
Tue Mar 11 08:54:24 EST 2003
Frauke -
When you change the projection to Gauß-Krüger, you must change the EXTENT statement to represent coordinates in that projected coordinate system. The values in the EXTENT statement are always coordinates in the MAP file's PROJECTION.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: frauke.trurnit at gmx.de [mailto:frauke.trurnit at gmx.de]
Sent: Tuesday, March 11, 2003 2:48 AM
To: mapserver-users at lists.gis.umn.edu
Cc: arnulf.christl at ccgis.de; stepan.kafka at centrum.cz
Subject: Re: [Mapserver-users] projection problem
Hi Anrulf, hi Stepan,
If I use Gauß-Krüger (init=EPSG:31493), no more map appears.
Frauke
NAME 'Bundestagswahlkreise 2002'
STATUS ON
EXTENT 5.24 47.29 15.33 55.33
UNITS dd
PROJECTION
'init=epsg:31493'
END
LAYER
TYPE POLYGON
STATUS ON
DATA 'wahlkreise2002'
PROJECTION
'init=epsg:4326'
END
CLASSITEM 'Name'
CLASS
NAME 'Wahlkreise'
EXPRESSION /./
OUTLINECOLOR 128 128 128
COLOR 255 255 0
TEMPLATE 'wahlkreise.html'
END
END
> Hi,
> the map looks correct - just like specified with 4326 which ist "ETRS89".
> If
> you want to have it look like we are used to in Germany you have to
> project
> it in Gauß-Krüger or similar.
> Regards, Arnulf.
> MAP
> NAME "Germany"
> STATUS ON
> #EXTENT 5.88 46.6213 15 55.7187
> EXTENT 2886610 5230448 4285190 6130010 #5.88 46.6213 15 55.7187
> PROJECTION
> "init=EPSG:31493" # projection of the whole
> project
> END
> LAYER
> NAME "Topographie"
> STATUS ON
> DATA "d:/umn/data/hynet_polygon.shp"
> TYPE POLYGON
> TEMPLATE "templates/query.html"
> HEADER "templates/query_header.html"
> FOOTER "templates/query_footer.html"
> TOLERANCE 20
> TOLERANCEUNITS PIXELS
> PROJECTION
> "init=EPSG:4326" # projection of the data
> END
> CLASSITEM "HYPYTYPE"
> UNITS METERS
> SIZEUNITS PIXELS
+++ GMX - Mail, Messaging & more http://www.gmx.net +++
Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
