[Mapserver-users] WMS
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Tue Mar 11 09:35:59 EST 2003
--=====================_113152454==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
Ed,
thanks for the quick answer. But the answer is: yes... As the WMS service
from where I want to retrieve a layer, does for sure work as it has been
implemented into another application, the problem can hardly be on this
side. I think, something is wrong on the map-file side. As the BBox and
other parameters are produced automatically by MapServer, the URL used in
the CONNECTION line below should be correct...
Just to be sure: Can I have a map-file with multiple local layers, which
are accessed normally, and in addition a couple of WMS layers, accessed as
shown below? I was just wondering if MapServer would be capable of merging
then two, three or four different images, as each WMS service sends its own
image back. I know that I can overlay different requests and thus images
using simple HTML code, but I am not so sure about the method I just wanted
to implement. Stupid question? Hmmm...
Ciao,
Stefan
>Stefan -
>We don't know what your data are, so we can't tell whether the metadata
>(the projection in particular) are correct - you need to check that.  You
>also need to be requesting map extents (the WMS BBox) in coordinates that
>match both the projection of your map and the extents of your data.
>     - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA  01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: Stefan Schwarzer [mailto:stefan.schwarzer at grid.unep.ch]
>Sent: Tuesday, March 11, 2003 9:11 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] WMS
>Hi all,
>thanks for the input. Right, after setting an environment variable the
>ugly warning disappeared.
>But I have still the problem that the WMS layer is not showing up. Any
>hints into this direction? Are the Metadata in the Layer definition
>correct? Do I have to define anything else in the mapfile? [I am working
>with MapScript, v3.5]
>Thanks,
>Stefan
>>Stefan -
>>Marc's response is correct; you will find information about this problem
>>in the "FAQ / Common Problems" section of the WMS Server page at
>><http://mapserver.gis.umn.edu/doc/wms-server-howto.html>http://mapserver.gis.umn.edu/doc/wms-server-howto.html
>>     - Ed
>>Ed McNierney
>>ed at topozone.com
>>(978) 251-4242
>>Sent: Tuesday, March 11, 2003 4:09 AM
>>Subject: [Mapserver-users] WMS
>>Hi all,
>>after spending quite some time on this WMS query subject, I am getting a
>>bit frustrated. I read (almost?) all info on this subject. But still I
>>don't succeed.
>>In the moment my computer is nerving me with this message:
>>Warning: MapServer Error in msProcessProjection(): no system list, errno:
>>2 in e:\inetpub\wwwroot\geo_map\map.php on line 275
>>Ok, I know, this is related to the projection list. But: all my other
>>services (local and WMS-server) are running quite well. So I don't
>>understand why it's coming up with this message. Below the Layer
>>definition I use. Any ideas?
>>Stefan
>>LAYER
>>         NAME "test"
>>         METADATA
>>                 "wms_title" "test"
>>                 "wms_srs" "epsg:4326"
>>                 "wms_connectiontimeout" "1000"
>>         END
>>         TYPE RASTER
>>         STATUS ON
>>         CONNECTIONTYPE WMS
>>         CONNECTION
>> "http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE"
>>END
>>         _______________________________________
>>         Stefan Schwarzer
>>         Consultant on GEO
>>         UNEP/DEWA/GRID-Geneva
>>         Chemin des Anemones 11
>>         CH - 1219 Chatelaine
>>         Switzerland
>>         Tel: (+41) 22.917.83.49
>>         Fax: (+41) 22.917.80.29
>>         Email: stefan.schwarzer at grid.unep.ch
>>         Internet: http://geodata.grid.unep.ch/
>         Stefan Schwarzer
>         Consultant on GEO
>         Switzerland
         Stefan Schwarzer
         Consultant on GEO
         Switzerland
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<font size=3>Ed,<br><br>
the CONNECTION line below should be correct...<br><br>
as shown below? I was just wondering if MapServer would be capable of
merging then two, three or four different images, as each WMS service
sends its own image back. I know that I can overlay different requests
and thus images using simple HTML code, but I am not so sure about the
method I just wanted to implement. Stupid question? Hmmm...<br><br>
Ciao,<br><br>
Stefan<br><br>
<br>
</font><blockquote type=cite class=cite cite><font face="arial" size=2 color="#0000FF">Stefan
-</font><font size=3><br>
&nbsp;<br>
</font><font face="arial" size=2 color="#0000FF">We don't know what your
data are, so we can't tell whether the metadata (the projection in
particular) are correct - you need to check that.&nbsp; You also need to
be requesting map extents (the WMS BBox) in coordinates that match both
data.</font><font size=3><br>
&nbsp;<br>
&nbsp;&nbsp;&nbsp; </font><font face="arial" size=2 color="#0000FF">-
Ed</font><font size=3><br><br>
</font><font size=2>Ed McNierney<br>
President and Chief Mapmaker<br>
TopoZone.com / Maps a la carte, Inc.<br>
73 Princeton Street, Suite 305<br>
North Chelmsford, MA&nbsp; 01863<br>
ed at topozone.com<br>
(978) 251-4242 <br>
</font>
<dl>
<dd><font face="tahoma" size=2>-----Original Message-----<br>
<dd>From:</b> Stefan Schwarzer
[<a href="mailto:stefan.schwarzer at grid.unep.ch" eudora="autourl">mailto:stefan.schwarzer at grid.unep.ch</a>]<br>
<dd>Sent:</b> Tuesday, March 11, 2003 9:11 AM<br>
<dd>To:</b> mapserver-users at lists.gis.umn.edu<br>
<dd>Subject:</b> RE: [Mapserver-users] WMS<br><br>
</font>
<dd><font size=3>Hi all,<br><br>
<dd>thanks for the input. Right, after setting an environment variable
the ugly warning disappeared.<br><br>
<dd>But I have still the problem that the WMS layer is not showing up.
Any hints into this direction? Are the Metadata in the Layer definition
with MapScript, v3.5]<br><br>
<dd>Thanks,<br><br>
<dd>Stefan<br><br>
<br>
<dd><font face="arial" size=2 color="#0000FF">Stefan
<dd>&nbsp;<br>
</font>
<dd><font face="arial" size=2 color="#0000FF">Marc's response is correct;
you will find information about this problem in the &quot;FAQ / Common
Problems&quot; section of the WMS Server page at
<a href="http://mapserver.gis.umn.edu/doc/wms-server-howto.html">http://mapserver.gis.umn.edu/doc/wms-server-howto.html</a></font><font size=3><br>
<dd>&nbsp;<br>
<dd>&nbsp;&nbsp;&nbsp; </font><font face="arial" size=2 color="#0000FF">-
</font>
<dd><font size=2>Ed McNierney<br>
<dd>President and Chief Mapmaker<br>
<dd>TopoZone.com / Maps a la carte, Inc.<br>
<dd>73 Princeton Street, Suite 305<br>
<dd>North Chelmsford, MA&nbsp; 01863<br>
<dd>ed at topozone.com<br>
<dd>(978) 251-4242 </font>
<dd>From: Stefan Schwarzer
<dd>Sent: Tuesday, March 11, 2003 4:09 AM
<dd>To: mapserver-users at lists.gis.umn.edu
<dd>Subject: [Mapserver-users] WMS<br><br>
</font>
<dd>after spending quite some time on this WMS query subject, I am
getting a bit frustrated. I read (almost?) all info on this subject. But
still I don't succeed. <br>
<dd>In the moment my computer is nerving me with this message:<br>
<dd>Warning: MapServer Error in msProcessProjection(): no system list,
errno: 2 in e:\inetpub\wwwroot\geo_map\map.php on line 275 <br>
<br>
<dd>Ok, I know, this is related to the projection list. But: all my other
definition I use. Any ideas?<br>
<dd>Stefan<br>
<br>
<dd>LAYER
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>NAME
&quot;test&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>METADATA
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_title&quot;
&quot;test&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_srs&quot;
&quot;epsg:4326&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_connectiontimeout&quot;
&quot;1000&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>END
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>TYPE
RASTER
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>STATUS
ON
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CONNECTIONTYPE
WMS
&quot;<a href="http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE" eudora="autourl">http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE</a>&quot;
<dd>END<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________<br><br>
</font>
<dd><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Stefan
Schwarzer
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Consultant
on GEO<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>UNEP/DEWA/GRID-Geneva
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Chemin
des Anemones 11
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CH -
1219 Chatelaine
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Switzerland<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Tel:
(+41) 22.917.83.49
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Fax:
(+41) 22.917.80.29<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Email:
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Internet:
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a></font>
<dd><font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________
</blockquote>
</dl><br>
</font><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Stefan
Schwarzer<br>
</b><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Consultant
on GEO<br><br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>UNEP/DEWA/GRID-Geneva<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Chemin des
Anemones 11<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CH - 1219
Chatelaine<br>
<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Tel: (+41)
22.917.83.49<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Fax: (+41)
22.917.80.29<br><br>
stefan.schwarzer at grid.unep.ch<br>
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a><br>
</font><font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________
<br>
</font></blockquote>
<x-sigsep><p></x-sigsep>
<font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________<br><br>
</font><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><b>Stefan
Schwarzer<br>
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Switzerland<br><br>
22.917.83.49<br>
</font><font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________</font></body>
</html>
--=====================_113152454==.ALT--
