[Mapserver-users] WMS
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Tue Mar 11 10:13:39 EST 2003
--=====================_115412564==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
Ed,
I used before TYPE RASTER, but nothing moved. So I tried it with POINT -
which didn't make too much sense. But one never knows...
>Stefan -
>You didn't mention PHP <g> - so you're using MapScript, not MapServer?
>Yes, the TYPE should certainly be RASTER, not POINT.  That may not be your
>only problem, but it's going to be a problem.
>     - Ed
>-----Original Message-----
>From: Stefan Schwarzer [mailto:stefan.schwarzer at grid.unep.ch]
>Sent: Tuesday, March 11, 2003 10:02 AM
>To: Ed McNierney; mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] WMS
>Ed,
>no, I am getting no more errors. The layer just does not appear. The layer
>is turned on, and as you said, not only because of STATUS ON, but in my
>PHP script I tell explicitly to turn it on again (actually after turning
>all layers off):
>$mapLayer = $map -> getlayerbyname("test");
>$mapLayer -> set("status", 1);
>Where does the "wms_title" refer to? Should it have the same title as the
>WMS service layer? What is TYPE in this case? Originally it's a POINT
>shapefile, but now it would be anyway a raster/image, no? When I try to
>display the layer locally, everything turns up nicely.
>LAYER
>         NAME 'test'
>         METADATA
>                 'wms_title' 'test'
>                 'wms_srs' 'epsg:4326'
>                 'wms_connectiontimeout' '1000'
>         END
>         TYPE POINT
>         STATUS ON
>         CONNECTIONTYPE WMS
>         CONNECTION
> 'http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE'
>END
>Ciao,
>Stefan
>>Stefan -
>>You can certainly  use multiple local and remote layers.
>>Now that the PROJ problem is fixed, are you getting any errors?  Is the
>>layer simply not appearing?  Is the layer turned on (STATUS ON isn't enough)?
>>     - Ed
>>Sent: Tuesday, March 11, 2003 9:36 AM
>>Ed,
>>thanks for the quick answer. But the answer is: yes... As the WMS service
>>from where I want to retrieve a layer, does for sure work as it has been
>>implemented into another application, the problem can hardly be on this
>>side. I think, something is wrong on the map-file side. As the BBox and
>>other parameters are produced automatically by MapServer, the URL used in
>>the CONNECTION line below should be correct...
>>Just to be sure: Can I have a map-file with multiple local layers, which
>>are accessed normally, and in addition a couple of WMS layers, accessed
>>as shown below? I was just wondering if MapServer would be capable of
>>merging then two, three or four different images, as each WMS service
>>sends its own image back. I know that I can overlay different requests
>>and thus images using simple HTML code, but I am not so sure about the
>>method I just wanted to implement. Stupid question? Hmmm...
>>Ciao,
>>Stefan
>>>Stefan -
>>>We don't know what your data are, so we can't tell whether the metadata
>>>(the projection in particular) are correct - you need to check
>>>that.  You also need to be requesting map extents (the WMS BBox) in
>>>coordinates that match both the projection of your map and the extents
>>>of your data.
>>>     - Ed
>>>Ed McNierney
>>>President and Chief Mapmaker
>>>TopoZone.com / Maps a la carte, Inc.
>>>73 Princeton Street, Suite 305
>>>North Chelmsford, MA  01863
>>>ed at topozone.com
>>>(978) 251-4242
>>>Sent: Tuesday, March 11, 2003 9:11 AM
>>>To: mapserver-users at lists.gis.umn.edu
>>>Hi all,
>>>thanks for the input. Right, after setting an environment variable the
>>>ugly warning disappeared.
>>>But I have still the problem that the WMS layer is not showing up. Any
>>>hints into this direction? Are the Metadata in the Layer definition
>>>correct? Do I have to define anything else in the mapfile? [I am working
>>>with MapScript, v3.5]
>>>Thanks,
>>>Stefan
>>>>Stefan -
>>>>Marc's response is correct; you will find information about this
>>>>problem in the "FAQ / Common Problems" section of the WMS Server page
>>>>at
>>>><http://mapserver.gis.umn.edu/doc/wms-server-howto.html>http://mapserver.gis.umn.edu/doc/wms-server-howto.html
>>>>     - Ed
>>>>Ed McNierney
>>>>ed at topozone.com
>>>>(978) 251-4242
>>>>Sent: Tuesday, March 11, 2003 4:09 AM
>>>>Subject: [Mapserver-users] WMS
>>>>Hi all,
>>>>after spending quite some time on this WMS query subject, I am getting
>>>>a bit frustrated. I read (almost?) all info on this subject. But still
>>>>I don't succeed.
>>>>In the moment my computer is nerving me with this message:
>>>>Warning: MapServer Error in msProcessProjection(): no system list,
>>>>errno: 2 in e:\inetpub\wwwroot\geo_map\map.php on line 275
>>>>Ok, I know, this is related to the projection list. But: all my other
>>>>services (local and WMS-server) are running quite well. So I don't
>>>>understand why it's coming up with this message. Below the Layer
>>>>definition I use. Any ideas?
>>>>Stefan
>>>>LAYER
>>>>         NAME "test"
>>>>         METADATA
>>>>                 "wms_title" "test"
>>>>                 "wms_srs" "epsg:4326"
>>>>                 "wms_connectiontimeout" "1000"
>>>>         END
>>>>         TYPE RASTER
>>>>         STATUS ON
>>>>         CONNECTIONTYPE WMS
>>>>         CONNECTION
>>>> "http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE"
>>>>END
>>>>         _______________________________________
>>>>         Stefan Schwarzer
>>>>         Consultant on GEO
>>>>         UNEP/DEWA/GRID-Geneva
>>>>         Chemin des Anemones 11
>>>>         CH - 1219 Chatelaine
>>>>         Switzerland
>>>>         Tel: (+41) 22.917.83.49
>>>>         Fax: (+41) 22.917.80.29
>>>>         Email: stefan.schwarzer at grid.unep.ch
>>>>         Internet: http://geodata.grid.unep.ch/
>>         Stefan Schwarzer
>>         Consultant on GEO
>>         Switzerland
>         Stefan Schwarzer
>         Consultant on GEO
>         Switzerland
>         Stefan Schwarzer
>         Consultant on GEO
>         Switzerland
         Stefan Schwarzer
         Consultant on GEO
         Switzerland
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<font size=3>Ed,<br><br>
which didn't make too much sense. But one never knows...<br><br>
<br>
</font><blockquote type=cite class=cite cite><font face="arial" size=2 color="#0000FF">Stefan
-</font><font size=3><br>
&nbsp;<br>
</font><font face="arial" size=2 color="#0000FF">You didn't mention PHP
&lt;g&gt; - so you're using MapScript, not
MapServer?</font><font size=3><br>
&nbsp;<br>
</font><font face="arial" size=2 color="#0000FF">Yes, the TYPE should
certainly be RASTER, not POINT.&nbsp; That may not be your only problem,
but it's going to be a problem.</font><font size=3><br>
&nbsp;<br>
&nbsp;&nbsp;&nbsp; </font><font face="arial" size=2 color="#0000FF">-
Ed</font><font size=3><br>
</font>
<dl>
<dd><font face="tahoma" size=2>-----Original Message-----<br>
<dd>From:</b> Stefan Schwarzer
[<a href="mailto:stefan.schwarzer at grid.unep.ch" eudora="autourl">mailto:stefan.schwarzer at grid.unep.ch</a>]<br>
<dd>Sent:</b> Tuesday, March 11, 2003 10:02 AM<br>
<dd>To:</b> Ed McNierney; mapserver-users at lists.gis.umn.edu<br>
<dd>Subject:</b> RE: [Mapserver-users] WMS<br><br>
</font>
<dd><font size=3>Ed,<br><br>
<dd>no, I am getting no more errors. The layer just does not appear. The
layer is turned on, and as you said, not only because of STATUS ON, but
in my PHP script I tell explicitly to turn it on again (actually after
turning all layers off):<br><br>
<dd>$mapLayer = $map -&gt; getlayerbyname(&quot;test&quot;);<br>
<dd>$mapLayer -&gt; set(&quot;status&quot;, 1);<br><br>
<dd>Where does the &quot;wms_title&quot; refer to? Should it have the
same title as the WMS service layer? What is TYPE in this case?
Originally it's a POINT shapefile, but now it would be anyway a
raster/image, no? When I try to display the layer locally, everything
turns up nicely.<br><br>
<dd>LAYER<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>NAME
'test'<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>METADATA<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>'wms_title'
'test'<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>'wms_srs'
'epsg:4326'<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>'wms_connectiontimeout'
'1000'<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>END<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>TYPE
POINT<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>STATUS
ON<br>
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CONNECTIONTYPE
WMS<br>
'<a href="http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE" eudora="autourl">http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE</a>'<br>
<dd>END<br><br>
<br>
<dd>Ciao,<br><br>
<dd>Stefan<br><br>
<br>
<dd><font face="arial" size=2 color="#0000FF">Stefan
<dd>&nbsp;<br>
</font>
<dd><font face="arial" size=2 color="#0000FF">You can certainly&nbsp; use
multiple local and remote layers.</font><font size=3><br>
<dd>&nbsp;<br>
</font>
<dd><font face="arial" size=2 color="#0000FF">Now that the PROJ problem
is fixed, are you getting any errors?&nbsp; Is the layer simply not
appearing?&nbsp; Is the layer turned on (STATUS ON isn't
enough)?</font><font size=3><br>
<dd>&nbsp;<br>
</font>
<dd><font face="arial" size=2 color="#0000FF">&nbsp;&nbsp;&nbsp; -
Ed</font><font size=3></font>
<dd>From: Stefan Schwarzer
<dd>Sent: Tuesday, March 11, 2003 9:36 AM
<dd>To: Ed McNierney; mapserver-users at lists.gis.umn.edu
<dd>Subject: RE: [Mapserver-users] WMS<br><br>
</font>
<dd>thanks for the quick answer. But the answer is: yes... As the WMS
service from where I want to retrieve a layer, does for sure work as it
has been implemented into another application, the problem can hardly be
on this side. I think, something is wrong on the map-file side. As the
BBox and other parameters are produced automatically by MapServer, the
URL used in the CONNECTION line below should be correct...<br>
<dd>Just to be sure: Can I have a map-file with multiple local layers,
which are accessed normally, and in addition a couple of WMS layers,
accessed as shown below? I was just wondering if MapServer would be
capable of merging then two, three or four different images, as each WMS
service sends its own image back. I know that I can overlay different
requests and thus images using simple HTML code, but I am not so sure
about the method I just wanted to implement. Stupid question?
Hmmm...<br>
<dd>Ciao,<br>
<dd>Stefan<br>
<br><br>
<dd>&nbsp; </font>
<dd><font face="arial" size=2 color="#0000FF">We don't know what your
data are, so we can't tell whether the metadata (the projection in
particular) are correct - you need to check that.&nbsp; You also need to
be requesting map extents (the WMS BBox) in coordinates that match both
the projection of your map and the extents of your
data.</font><font size=3>
<dd>&nbsp;
<dd>&nbsp;&nbsp;&nbsp; </font><font face="arial" size=2 color="#0000FF">-
Ed</font><font size=3><br><br>
</font>
<dd><font size=2>Ed McNierney
<dd>President and Chief Mapmaker
<dd>TopoZone.com / Maps a la carte, Inc.
<dd>73 Princeton Street, Suite 305
<dd>North Chelmsford, MA&nbsp; 01863
<dd>ed at topozone.com
<dd>(978) 251-4242 </font>
<dd>Sent: Tuesday, March 11, 2003 9:11 AM
<dd>To: mapserver-users at lists.gis.umn.edu
</font>
<dd><font size=3>Hi all,
<dd>thanks for the input. Right, after setting an environment variable
the ugly warning disappeared.
<dd>But I have still the problem that the WMS layer is not showing up.
Any hints into this direction? Are the Metadata in the Layer definition
<dd>Thanks,
<dd>Stefan<br>
<br><br>
<dd>&nbsp; </font>
<dd><font face="arial" size=2 color="#0000FF">Marc's response is correct;
you will find information about this problem in the &quot;FAQ / Common
Problems&quot; section of the WMS Server page at
<a href="http://mapserver.gis.umn.edu/doc/wms-server-howto.html">http://mapserver.gis.umn.edu/doc/wms-server-howto.html</a></font><font size=3>
</font>
<dd>Sent: Tuesday, March 11, 2003 4:09 AM
<dd>Subject: [Mapserver-users] WMS<br><br>
</font>
<dd>after spending quite some time on this WMS query subject, I am
getting a bit frustrated. I read (almost?) all info on this subject. But
still I don't succeed.
<dd>In the moment my computer is nerving me with this message:
<dd>Warning: MapServer Error in msProcessProjection(): no system list,
<dd>Ok, I know, this is related to the projection list. But: all my other
<dd>Stefan
<dd>LAYER
&quot;test&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_title&quot;
&quot;test&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_srs&quot;
&quot;epsg:4326&quot;
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>&quot;wms_connectiontimeout&quot;
&quot;1000&quot;
RASTER
ON
WMS
&quot;<a href="http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE" eudora="autourl">http://xxx.xx.xxx.xx/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&amp;WMTVER=1.0.0&amp;LAYERS=people&amp;FORMAT=PNG&amp;TRANSPARENT=TRUE</a>&quot;
<dd>END
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________<br><br>
</font>
<dd><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Stefan
Schwarzer
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Consultant
on GEO
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>UNEP/DEWA/GRID-Geneva
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Chemin
des Anemones 11
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CH -
1219 Chatelaine
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Switzerland
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Tel:
(+41) 22.917.83.49
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Fax:
(+41) 22.917.80.29
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Email:
<dd><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Internet:
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a></font><font size=3>
</blockquote></blockquote>
</dl><br>
</font><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Stefan
Schwarzer<br>
on GEO<br><br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>UNEP/DEWA/GRID-Geneva<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Chemin des
Anemones 11<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>CH - 1219
Chatelaine<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Switzerland<br><br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Tel: (+41)
22.917.83.49<br>
<x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Fax: (+41)
22.917.80.29<br><br>
stefan.schwarzer at grid.unep.ch<br>
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a><br>
</font><font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________
</blockquote><br>
Schwarzer<br>
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
<br>
22.917.83.49<br>
<br>
<dl><br>
</dl><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________<br><br>
Schwarzer<br>
</b><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>Consultant
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
22.917.83.49<br>
<br>
</font></blockquote>
<x-sigsep><p></x-sigsep>
<font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________<br><br>
</font><font size=2><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab><b>Stefan
Schwarzer<br>
on GEO<br><br>
Anemones 11<br>
Chatelaine<br>
22.917.83.49<br>
</font><font size=3><x-tab>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</x-tab>_______________________________________</font></body>
</html>
--=====================_115412564==.ALT--
