[Mapserver-users] WMS
Daniel Morissette
morissette at dmsolutions.ca
Tue Mar 11 10:36:16 EST 2003
This is a multi-part message in MIME format.
--------------4D34A1A1AD019B607BBC5B19
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Stefan Schwarzer wrote:
> I used before TYPE RASTER, but nothing moved. So I tried it with POINT
> - which didn't make too much sense. But one never knows...
Layer type should be set to RASTER but if you set it to POINT then
MapServer will change it back to RASTER internally. I was unable to
reproduce the problem, there must be something missing at the map
level. Also note that and the wms_srs metadata value should be
"EPSG:4326" in uppercase but that didn't seem to have an impact in this
case.
I attached below a mapfile that does work for me. You should be able to
isolate the problem if you compare it with yours.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Content-Type: text/plain; charset=us-ascii;
name="testwms.map"
Content-Disposition: inline;
filename="testwms.map"
MAP
NAME "DEMO"
EXTENT -180 -90 180 90
IMAGECOLOR 255 255 255
IMAGETYPE PNG
INTERLACE TRUE
SIZE 400 300
STATUS ON
UNITS METERS
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
NAME 'test'
METADATA
'wms_title' 'test'
'wms_srs' 'epsg:4326'
'wms_connectiontimeout' '1000'
END
TYPE POINT
STATUS ON
CONNECTIONTYPE WMS
CONNECTION
'http://gridss.grid.unep.ch/cgi-bin/mapserv_client?map=e%3A%5Cinetpub%5Cwwwroot%5Cip%5Cdemo.map&WMTVER=1.0.0&LAYERS=people&FORMAT=PNG&TRANSPARENT=TRUE'
END
END
--------------4D34A1A1AD019B607BBC5B19--
