[Mapserver-users] forcing map extent
James Jefferson
jjeffers at aprsworld.net
Tue Mar 11 16:29:16 EST 2003
Hi list,
I am using shp2img is a backend for generating maps for an application I
am developing. The software that is requesting the images has already
calculated the map extent that it wants, and all mapserver has to do is
return exactly that image. In some cases the software will request a
distorted map.
Mapserver (and shp2img) will re-calculate the extent of the map to contain
at least the extent specified and sometimes bigger. How can I prevent
mapserver from doing this?
Searching the archives I've found this thread from 2000:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0003/threads.html#00075
Was this ever implemented? I don't see any reference to it in the code. If
it hasn't been implemented, how should I go about doing that. It appears
that msAdjustExtent(rectObj *rect, int width, int height) controls part of
this. Where else should I be looking?
Thanks in advance -
-Jim
