[Mapserver-users] _gxx_personality_v0
Wed Mar 12 11:52:00 EST 2003
> gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include
> shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lttf -lpng -lz  -ltiff
> -ljpeg -lttf -lpng -lz  -ljpeg          -lm   -o shp2img
> ./libmap.a(mapogr.o)(.eh_frame+0x11): undefined reference to
> `__gxx_personality_v0'
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
Folks,
Just in case it isn't in other responses from earlier, a solution to this
(presumably) is to use the C++ compiler as the linker instead of the C
compiler.  This can be accomplished by editing the makefile and changing
"LD=gcc" to "LD=c++" or more generally to "LD=$(CXX)".  Or just do the
same on the command line "make LD=c++".
Presumably the 3.7 configure scripts will produce a Makefile with this
done if they don't already.
Actually, I don't get this error myself on Red Hat 8, with gcc 3.2.  It would
appear to be because the libgdal.1.1.so is already linked against
/usr/lib/libstdc++.so.5 which provides the C++ support.
If anyone running into this problem finds that my suggested change to LD
does not solve their problem, I would encourage them to contact me directly
by email, and we will resolve the problem and I will try to see the fix gets
into 3.7 (and perhaps a 3.6.5) if it has not already.
PS. If you don't need OGR just configure without it and you won't run into
this problem.
Best regards,
