[Mapserver-users] MINSCALE in webobj
Ed McNierney ed at topozone.com
Thu Mar 13 08:32:12 EST 2003
Vincent -
Yes, I've used it and it has always seemed just fine to me.  You should display the [scale] value on your map to make sure the units are indeed correct, and see whether that value becomes less than your MINSCALE value.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Vincent Schut [mailto:schut at sarvision.com]
Sent: Thursday, March 13, 2003 3:58 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MINSCALE in webobj
Did any of you succesfully use the MINSCALE item in the webobject of the
mapfile? The mapfile reference sais:
MINSCALE [double]
Minimum scale at which this interface is valid. When a user reuqests a map at
a smaller scale, MapServer automatically returns the map at this scale. This
effectively prevents the user from zooming in too far.
I tried this but could not get it working.
If anyone can give me a hint, please do so.
And before getting the too obvious hint: yes, my units are right. Everything
works, just the minscale item does nothing. I'm using mapserver through
php_mapscript, version 3.7 (cvs of not too long ago).
Note btw that this is a different MINSCALE than the one used in a LAYER
object.
Regards,
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
