[Mapserver-users] Re: Mandrake 9 Problem
Richard Greenwood
rich at greenwoodmap.com
Thu Mar 13 09:02:03 EST 2003
--=======6143ADE=======
Content-Type: text/plain; x-avg-checked=avg-ok-6480487D; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
I use the patched version of gd 1.8.4 available at:
http://www.rime.com.au/gd/
So my configure looks like this:
-with-gd=../gd-1.8.4
My notes also say that I created a symbolic link in /usr/lib to libpng.so.3
named "libpng.so.22",but I can not remember why.
Good luck,
Rich
At 10:54 AM 3/13/2003 +0100, Till Adams wrote:
>Dear Rich,
>I found your name on the mapserver mailing list archive. I guess you run
>mapserver under mandrake 9.
>I wanted to try your workaround with gcc 3.2 - my problem is:
>When running the ./configure everything works fine except that gd is not
>found. Mapserver looks for libgd.so/libgd.a or gd.h in usr/lib/ - there is
>only a libgd.so.1.8.4 and a libgd.so.1. So i tried to give symbolic link
>named libgd.so, ut the same error message appears, saying, that my gd is
>not compiled correctly. I've seen there are some different gd's on the
>rpm-find.net, and the gd's for mandrake write gifs only. Maybe the problem
>is there.
>Did you have the same gd problems and do you have any ideas? Every hint
>would help a lot!
>Thanks in advance
>Till
>Dipl. Geogr. Till Adams
>terrestris, Paulsen&Adams GbR
>Meckenheimer Allee 166 * 53115 Bonn
>Tel.: 0228 73 9647 * Fax.: 0228 73 6538
>info at terrestris.de * www.terrestris.de
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
--=======6143ADE=======--
