[Mapserver-users] limiting query results
Fawcett, David
David.Fawcett at state.mn.us
Thu Mar 13 14:32:02 EST 2003
For the instance of the user selecting the whole county with the box, could you use scale-dependent layers so they don't have the option to query the whole county.
I am sure that there is a more elegant solution, but this could prevent the crash you are describing.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: Ryan, Adam[SMTP:ARyan at co.linn.or.us]
> Sent: Thursday, March 13, 2003 1:02 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] limiting query results
> Dear List,
> I'm resending this because I can't find a cgi (not mapscript) solution.
> I want to limit the number of records returned by an NQUERY or and ITEMNQUERY, or the number of times mapserv sends the layer template. If the user makes a box around the whole county, or searches by [STREETNAME] =~ /ST/, for example, mapserv easily and quickly renders the image, but then spits out the layer template many thousands of times and ultimately crashes the browser.
> I can monitor the [rn] and take steps using javascript, but I can't stop mapserv from spitting out all the instances of the template.
> I can't use MAXFEATURES because that limits the number of records that are searched, not the number returned.
> Any ideas?
> Adam Ryan
> Linn County
